大哥大姐,我也遇见这个问题,一直解决不掉,急死了。 我仔细阅读了论坛里的其它相关帖子,才猛然发现,我把数据总线的传输方向置为输出output了,改成双向bidir就可以了!不知道您说的数据总线的传输方向是哪个地方的?难道是flash? 下面是我 的出错,请我看看怎么解决。万分感谢!! #! /bin/sh # # This file was automatically generated by the Nios II IDE Flash Programmer. # # It will be overwritten when the flash programmer options change. # cd D:/mychengxv/MYFPGA/flash/software/hello_world_0/Debug # Creating .flash file for the FPGA configuration $SOPC_KIT_NIOS2/bin/sof2flash --offset=0x000000 --input=D:/mychengxv/MYFPGA/flas h/flash_time_limited.sof --output=flash_time_limited.flash Info: ******************************************************************* Info: Running Quartus II Convert_programming_file Info: Command: quartus_cpf --no_banner --convert D:/mychengxv/MYFPGA/flash/flash _time_limited.sof flash_time_limited.rbf File D:/mychengxv/MYFPGA/flash/flash_time_limited.sof contains one or more time- limited megafunctions that support the OpenCore Plus feature that will not work after the hardware evaluation time expires. Refer to the Messages window for eva luation time details. Info: SRAM Object File D:/mychengxv/MYFPGA/flash/flash_time_limited.sof contains time-limited megafunction that supports OpenCore Plus feature -- Vendor: 0x6AF7 , Product: 0x00A2 SOF Data item missing input file Error: Convert Programming Files was NOT successful -- refer to messages that ap pear above this message for more information Error: Quartus II Convert_programming_file was unsuccessful. 1 error, 0 warnings Error: Processing ended: Sat Dec 08 14:30:27 2007 Error: Elapsed time: 00:00:01 2007-12-8 14:30:27 - (严重) sof2flash: Read error: File: flash_time_limited.rbf no t found, exiting 2007-12-8 14:30:27 - (严重) sof2flash: Error retrieving data from flash_time_limit ed.rbf # Programming flash with the FPGA configuration $SOPC_KIT_NIOS2/bin/nios2-flash-programmer --cable='USB-Blaster [USB-0]' --base= 0x01000000 flash_time_limited.flash flash_time_limited.flash: Unable to open input file # Creating .flash file for the project $SOPC_KIT_NIOS2/bin/elf2flash --base=0x01000000 --end=0x13fffff --reset=0x100000 0 --input=hello_world_0.elf --output=cfi_flash_1.flash --boot=$SOPC_KIT_NIOS2/co mponents/altera_nios2/boot_loader_cfi.srec # Programming flash with the project $SOPC_KIT_NIOS2/bin/nios2-flash-programmer --cable='USB-Blaster [USB-0]' --base= 0x01000000 cfi_flash_1.flash Using cable "USB-Blaster [USB-0]", device 1, instance 0x00 Resetting and pausing target processor: No CFI table found at address 0x01000000 OK Leaving target processor paused |
