同样的程序在7.0版本上没问题 但在6.1的版本上出现下列问题 **** Build of configuration Debug for project softwarezs **** make -s all Compiling hello_led.c... Linking softwarezs.elf... /cygdrive/c/altera/61/nios2eds/bin/nios2-gnutools/H-i686-pc-cygwin/bin/../lib/gcc/nios2-elf/3.4.1/../../../../nios2-elf/lib/libc.a(closer.o)(.text+0x18): In function `_close_r': /build/nios2/bin/nios2-gnutools/src/newlib/newlib/libc/reent/closer.c:53: warning: warning: close is not implemented and will always fail /cygdrive/c/altera/61/nios2eds/bin/nios2-gnutools/H-i686-pc-cygwin/bin/../lib/gcc/nios2-elf/3.4.1/../../../../nios2-elf/lib/libc.a(lseekr.o)(.text+0x20): In function `_lseek_r': /build/nios2/bin/nios2-gnutools/src/newlib/newlib/libc/reent/lseekr.c:58: warning: warning: lseek is not implemented and will always fail Info: (softwarezs.elf) 44 KBytes program size (code + initialized data). Info: 8189 KBytes free for stack + heap. Post-processing to create epcs_controller_boot_rom.flash Post-processing to create cfi_flash.flash Hardware simulation is not enabled for the target SOPC Builder system. Skipping creation of hardware simulation model contents and simulation symbol files. (Note: This does not affect the instruction set simulator.) Build completed in 7.907 seconds 出现问题后把6.1的repare了一次,还是这样 请问高手怎么解决? |
