3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
92
93
94
95
96
97
98
99
100
101
102
103
104
105
| #!/usr/bin/ksh93
FPATH="/usr/local/functions/shellcurses"
initscr
SCRWID="${MAX_COLS}"
SCRLEN="${MAX_LINES}"
clear
#### Display a two line header, centered on the screen
HEADER1="Shell Curses Example 5"
HEADER2="Data Entry Screen"
mvaddstr 1 $(( ( SCRWID - ${#HEADER1} ) / 2 )) "${HEADER1}"
mvaddstr 2 $(( ( SCRWID - ${#HEADER2} ) / 2 )) "${HEADER2}"
#### Define the user entry prompts
DOTS="........................................"
PRMPT[1]="Enter an existing directory name"
PRMPT[2]="Enter an existing regular file name"
PRMPT[3]="Enter an alpha-numeric value"
PRMPT[4]="Enter a numeric value"
PRMPT[5]="Enter an executable file name"
PCNT="${#PRMPT[@]}"
#### Display the numbered data entry prompt with trailing dots
for IDX in "${!PRMPT[@]}"
do
(( DOTWID = ( SCRWID / 2 ) - ( ${#PRMPT[IDX]} + 4 ) ))
PRMPT[IDX]="${PRMPT[IDX]}${DOTS:0 {DOTWID}}"
mvaddstr $(( IDX + 4 )) 2 "${IDX}: ${PRMPT[IDX]}...:"
done
DATACOL="$(( ${#PRMPT[1]} + 10 ))"
#### Prompt the user for a selection
mvaddstr $(( SCRLEN - 3 )) 2 "Select a line number to enter data:"
#### Read the users data line number selection from the screen
while :
do
#### Read the line number entered by the user
mvclrtoeol $(( SCRLEN - 3 )) 40
refresh
ANS="$( getstr )"
#### clear the status line and re-display the default status message
mvclrtoeol $(( SCRLEN - 2 )) 2
mvaddstr $(( SCRLEN - 2 )) 2 "( 0 = Exit )"
#### Validate the user entered line number, if invalid go back and ask again
[[ "_${ANS}" == "_0" ]] && exit 0
if [[ "_${ANS}" != _+([[:digit:]]) ]] || (( ANS < 1 )) || (( ANS > PCNT ))
then
continue
fi
#### Read the line data from the user entry
mvclrtoeol $(( ANS + 4 )) ${DATACOL}
refresh
DATA[${ANS}]="$( getstr )"
attrset rev
#### Check the validity of the line 1 data as entered by the user
if (( ANS == 1 )) && [[ ! -d "${DATA[${ANS}]}" ]]
then
mvaddstr $(( SCRLEN - 2 )) 2 "ERROR: Invalid Directory Name"
fi
#### Check the validity of the line 2 data as entered by the user
if (( ANS == 2 )) && [[ ! -f "${DATA[${ANS}]}" ]]
then
mvaddstr $(( SCRLEN - 2 )) 2 "ERROR: Invalid Regular File Name"
fi
#### Check the validity of the line 3 data as entered by the user
if (( ANS == 3 )) && [[ "_${DATA[${ANS}]}" != _+([[:alnum:]]) ]]
then
mvaddstr $(( SCRLEN - 2 )) 2 "ERROR: Invalid Alpha-Numeric Value"
fi
#### Check the validity of the line 4 data as entered by the user
if (( ANS == 4 )) && [[ "_${DATA[${ANS}]}" != _+([[:digit:]]) ]]
then
mvaddstr $(( SCRLEN - 2 )) 2 "ERROR: Invalid Numeric Value"
fi
#### Check the validity of the line 5 data as entered by the user
if (( ANS == 5 )) && [[ ! -x "${DATA[${ANS}]}" ]]
then
mvaddstr $(( SCRLEN - 2 )) 2 "ERROR: File is not executable or
does not exist"
fi
attroff
refresh
done
endwin
exit ${ANS}
