3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
| type customEvent struct {
Type string `json:"type"`
Description string `json:"description"`
func CreateLoanApplication(stub shim.ChaincodeStubInterface, args []string) ([]byte, error) {
fmt.Println("Entering CreateLoanApplication")
if len(args) < 2 {
fmt.Println("Invalid number of args")
return nil, errors.New("Expected at least two arguments for loan application creation")
var loanApplicationId = args[0]
var loanApplicationInput = args[1]
err := stub.PutState(loanApplicationId, []byte(loanApplicationInput))
if err != nil {
fmt.Println("Could not save loan application to ledger", err)
return nil, err
var event = customEvent = {"createLoanApplication", "Successfully created loan application with ID " + loanApplicationId}
eventBytes, err ;= json.Marshal(&event)
if err != nil {
return nil, err
err = stub.SetEvent("evtSender", eventBytes)
if err != nil {
fmt.Println("Could not set event for loan application creation", err)
fmt.Println("Successfully saved loan application")
return nil, nil
