[讨论]Nios II工程模板 Hello World 和 Hello LED的区别
各位前辈,请教Nios II工程模板 Hello World 和 Hello LED到底区别在哪儿?
为什么从Hello World 建的工程最小得6K多(只是实现一个IO口输出),而Hello LED工程则可以少到200多字节?
是不是EP1C3在on chip memory里面也就只能运行个Hello World? 它的片上RAM只有7K多点,EP1C6也只有11K多
[此贴子已经被作者于2007-8-31 14:01:50编辑过]
********求知欲和创造欲是原动力********
区别在于hello world调用了printf函数
博客: http://NiosII.cublog.cn
我倒是想到了这一点
如果不优化代码的话,直接生成的Hello World代码有30几K,起码现在提示我还需37K的空间,我的on chip memory是4K
但是把printf函数屏蔽掉的话,只是一个空的main()函数,优化后的代码都有6K
而Hello LED生成的代码只有几百个字节,当然是没有用到printf函数
这个Hello World工程代码到底多在了哪儿?
"而Hello LED生成的代码只有几百个字节,当然是没有用到printf函数
这个Hello World工程代码到底多在了哪儿?"
你可以看看nios_led的说明:
 * This example is a freestanding program because it's entry point is the
 * function:
 *    void alt_main (void)
 * As opposed to "main()" as a "hosted" application would (see the
 * "hello_world" example).
 * Upon entry to alt_main():
 * - The CPU's caches (if any) have been initialized.
 * - The stack-pointer has been set.
 * - That's all. The rest is up to you.
 * If you modify this example and try to call C library functions such as
 * printf, they will NOT  work unless you explicitly initialize the system
 * If you wish to use C library calls, it is strongly suggested you start
 * with the hosted hello_world template which uses main() as it's entry
 * point.
 * On the other hand, if you want to write a program that gets-in even
 * earlier, you will need to provide your own assembly-language machine-setup
 * code by defining the symbol "_start". Any definition of _start in your
 * directory will override the library definition. You can find source code
 * for the Nios II library _start here:
这个版主不太冷 =========================== 我的中电网博客:http://blog.chinaecnet.com/u/20/index.htm
主要是alt_main.c和alt_sys_init.c引入的代码
而这俩文件又间接引入了很多设备驱动代码,比如系统包含定时器,则定时器的驱动会被自动加载到最终的可执行文件...
更详细的资料自己研究吧或者等我的书出版^_^
楼上前辈说的很明白,谢谢,而且你要出的书我看过介绍了,很好,期待中
对于Hello LED工程我是这么做的:
向导产生的.c文件中的代码我都删除了,我没有用alt_main()作为入口,而是用了main()函数
而且我还在上面成功驱动了1602字符液晶!完全IO口驱动,其实就是用了个IOWR()函数
继续学习研究中~~
