3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
| private[spark] object SparkSubmitDriverBootstrapper {
// Start the driver JVM
val filteredCommand = command.filter(_.nonEmpty)
val builder = new ProcessBuilder(filteredCommand)
val env = builder.environment()
if (submitLibraryPath.isEmpty && confLibraryPath.nonEmpty) {
val libraryPaths = confLibraryPath ++ sys.env.get(
Utils.libraryPathEnvName)
env.put(Utils.libraryPathEnvName, libraryPaths.mkString(
sys.props("path.separator")))
val process = builder.start()
// If we kill an app while it's running, its sub-process should be killed too.
Runtime.getRuntime().addShutdownHook(new Thread() {
override def run() = {
if (process != null) {
process.destroy()
process.waitFor()
// Redirect stdout and stderr from the child JVM
val stdoutThread = new RedirectThread(process.getInputStream,
System.out, "redirect stdout")
val stderrThread = new RedirectThread(process.getErrorStream,
System.err, "redirect stderr")
stdoutThread.start()
stderrThread.start()
// Redirect stdin to child JVM only if we're not running Windows. This is because the
// subprocess there already reads directly from our stdin, so we should avoid spawning a
// thread that contends with the subprocess in reading from System.in.
val isWindows = Utils.isWindows
val isSubprocess = sys.env.contains("IS_SUBPROCESS")
if (!isWindows) {
val stdinThread = new RedirectThread(System.in, process.getOutputStream,
"redirect stdin",propagateEof = true)
stdinThread.start()
// Spark submit (JVM) may run as a subprocess,and so this JVM should terminate on
// broken pipe, signaling that the parent process has exited.
//This is the case if the application is launched directly from python,
//as in the PySpark shell. In Windows,the termination logic is handled in java_gateway.py
if (isSubprocess) {
stdinThread.join()
process.destroy()
val returnCode = process.waitFor()
sys.exit(returnCode)
