初试Microtronix Linux遇到的问题
刚在NiosII IDE上安装完Microtronix Linux
按照指导书的步骤新建了一个linux kernel project,
然后Configure Kernel的时候却报下面的错误,
求助高人哈
Microtronix Linux Extensions
Version 1.4, Built June 20, 2005
make: Entering directory `/cygdrive/c/altera/kits/nios2_60/bin/eclipse/plugins/com.microtronix.nios2linux.kernel_1.4.0/linux-2.6.x'
/cygdrive/c/altera/kits/nios2_60/bin/eclipse/plugins/com.microtronix.nios2linux.kernel_1.4.0/linux-2.6.x/Makefile:486: .config: No such file or directory
  no emulation specific options.
  Using /cygdrive/c/altera/kits/nios2_60/bin/eclipse/plugins/com.microtronix.nios2linux.kernel_1.4.0/linux-2.6.x as source for kernel
  GEN    /cygdrive/c/altera/kits/nios2_60/bin/eclipse/workspace/firstlinux/build/Makefile
  CHK     include/linux/version.h
  UPD     include/linux/version.h
  SYMLINK include/asm -> include/asm-nios2nommu
  HOSTCC  scripts/basic/fixdep
scripts/basic/.fixdep.d: done.
  HOSTCC  scripts/basic/split-include
scripts/basic/.split-include.d: done.
  HOSTCC  scripts/basic/docproc
scripts/basic/.docproc.d: done.
  HOSTLD  scripts/kconfig/conf
scripts/kconfig/conf -s arch/nios2nommu/Kconfig
*** You have not yet configured your kernel!
*** Please run some configurator (e.g. "make oldconfig" or
*** "make menuconfig" or "make xconfig").
make[3]: *** [silentoldconfig] Error 1
make[2]: *** [silentoldconfig] Error 2
make[1]: *** [include/linux/autoconf.h] Error 2
make: *** [_all] Error 2
make: Leaving directory `/cygdrive/c/altera/kits/nios2_60/bin/eclipse/plugins/com.microtronix.nios2linux.kernel_1.4.0/linux-2.6.x'
博客: http://NiosII.cublog.cn
“`/cygdrive/c/altera/kits/nios2_60/bin/eclipse/plugins/com.microtronix.nios2linux.kernel_1.4.0/linux-2.6.x'
Microtronix Linux1.4只支持nios5.0或5.1
这个版主不太冷 =========================== 我的中电网博客:http://blog.chinaecnet.com/u/20/index.htm
are you sure??
我的一个网友就是在6.0上面跑的啊...
不建议采用运行Microtronix Linux,自己装一个linux,然后上网去下一个uclinux,比这个方便多了。
移植也方便多了。Microtronix Linux自用1.4以后就没有再升级过了,应该是支持5.1以上版本的,
在交流中前进,共同实现nios的应用。
呵呵,大家这么赏脸。
are you sure??
uclinux我以前6.0试过,不行,5.0和5.1我以前都试过,可以。
"Microtronix Linux自用1.4以后就没有再升级过了,应该是支持5.1以上版本的,"
是的,以后就没有升级了,但是正是没有升级,所以不支持5.1以上版本的,因为使用Microtronix Linux这样的三方工具开放不见得方便。
下面是Microtronix Linux1.4 自带pdf的说明
Software Requirements
 The Nios II Linux Distribution requires the following software packages to be installed on the host system:
 • Altera Quartus® II 5.0
 • Altera Nios II Development Kit 5.0 (Evaluation or Full)
可以看看uclinux的说明链接:
http://bbs.eccn.com/ecbbs/dispbbs.asp?boardID=9&ID=31199&page=1
[此贴子已经被作者于2007-9-4 22:02:00编辑过]
呵呵,谢谢大家喽...
官方说明确实只支持5.0版本...
只好再次重装啦^_^
[em07]
kzw版主:
你说:“
移植也方便多了。
没见到有这方面资料啊
小弟也想学习一下,不知道你说的这种方法该如何移植,
你能不能给一份教程之类的东西啊?
谢谢了!
你能不能给一份教程之类的东西啊?
可以看看uclinux的说明链接:
告一个邮箱,我发一些资料给你看看。
在交流中前进,共同实现nios的应用。
谢谢啊!我原来那个wilde.1的这几天总是登陆不上啊,不知为什么!!??
无奈我注册了一个新号。。。wilde。。
我的邮箱是wilde.2@163.com
方便时给我发一份吧,谢谢了
caopengly版主啊
你给的那个连接很久以前就关注过了。。。
就是下不了.....
难道是我以前的号有问题?
[em06][em01]
Quartus II 6.0是可以跑...Microtronix Linux 1.4我一直都是在6.0上跑沒什麼問題....
有問題一般都是與windows上其他安裝程式衝突到了..
run linux 我覺得看看http://nioswiki.jot.com/WikiHome/OperatingSystems/%C2%B5Clinux/LinuxHwselect
裡面內容我跑過一次很實用..
