3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
| // Open the bloggers RDF graph from the filesystem
InputStream in = new FileInputStream(new File("bloggers.rdf"));
// Create an empty in-memory model and populate it from the graph
Model model = ModelFactory.createMemModelMaker().createModel();
model.read(in,null); // null base URI, since model URIs are absolute
in.close();
// Create a new query
String queryString =
" REFIX foaf: <http://xmlns.com/foaf/0.1/> " +
"SELECT ?url " +
"WHERE {" +
" ?contributor foaf:name \"Jon Foobar\" . " +
" ?contributor foaf:weblog ?url . " +
Query query = QueryFactory.create(queryString);
// Execute the query and obtain results
QueryExecution qe = QueryExecutionFactory.create(query, model);
ResultSet results = qe.execSelect();
// Output query results
ResultSetFormatter.out(System.out, results, query);
// Important - free up resources used running the query
qe.close();
