3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
| <?php
$zip = new ZipArchive();
$filename = "newzip.zip";
if ($zip->open($filename, ZIPARCHIVE::CREATE)!==TRUE) {
exit("cannot open <$filename>\n");
$zip->addFromString("firstfile." . time() . ".txt", \
"This is the first file in our ZIP, added as
firstfile.txt.\n");
$zip->addFromString("testdir/secondfile." . time() . ".txt", \
"This is the second file in our ZIP,
added as secondfile.txt.\n");
$zip->addFile("testtext.txt");
echo "numfiles: " . $zip->numFiles . "\n";
$zip->close();
