在 PHP 应用程序中集成 Google Calendar(6)
图 5. 包含事件列表的 Web 页面 包含了 delete.php 脚本代码,该代码通过 GET 方法取得事件标识符,然后用标识符删除事件,方法和 相同:
清单 9. 删除事件1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
| <!DOCTYPE html
PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN"
"http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd">
<html xmlns="http://www.w3.org/1999/xhtml" xml:lang="en" lang="en">
<head>
<title>Deleting calendar events</title>
<style>
body {
font-family: Verdana;
li {
border-bottom: solid black 1px;
margin: 10px;
padding: 2px;
width: auto;
padding-bottom: 20px;
h2 {
color: red;
text-decoration: none;
span.attr {
font-weight: bolder;
</style>
</head>
<body>
<h1>Delete Event</h1>
<?php
// load classes
require_once 'Zend/Loader.php';
Zend_Loader::loadClass('Zend_Gdata');
Zend_Loader::loadClass('Zend_Gdata_ClientLogin');
Zend_Loader::loadClass('Zend_Gdata_Calendar');
Zend_Loader::loadClass('Zend_Http_Client');
// connect to service
$gcal = Zend_Gdata_Calendar::AUTH_SERVICE_NAME;
$user = "username@gmail.com";
$pass = "pass";
$client = Zend_Gdata_ClientLogin::getHttpClient($user, $pass, $gcal);
$gcal = new Zend_Gdata_Calendar($client);
// if event ID is present
// get event object from feed
// delete event
if (isset($_GET['id'])) {
try {
$event = $gcal->getCalendarEventEntry('http://www.google.com/calendar/
feeds/default/private/full/' . $_GET['id']);
$event->delete();
} catch (Zend_Gdata_App_Exception $e) {
echo "Error: " . $e->getResponse();
echo 'Event successfully deleted!';
} else {
echo 'No event ID available';
</body>
</html>
包含了 edit.php 脚本代码。
清单 10. 编辑事件1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
92
93
94
95
96
97
98
99
100
101
102
103
104
105
106
107
108
109
110
111
112
113
114
115
116
117
118
119
120
121
122
123
124
125
126
127
128
129
130
131
132
133
134
135
136
137
138
139
140
141
142
143
144
145
146
147
148
149
150
151
| <!DOCTYPE html
<head>
<title>Updating calendar events</title>
<style>
body {
li {
margin: 10px;
padding: 2px;
width: auto;
h2 {
color: red;
span.attr {
</style>
</head>
<body>
<h1>Edit Event</h1>
<?php
// load classes
$pass = "pass";
// get event details
if (!isset($_POST['submit'])) {
try {
} else {
die('ERROR: No event ID available!');
// format data into human-readable form
// populate a Web form with the record
$title = $event->title;
$when = $event->getWhen();
$startTime = strtotime($when[0]->getStartTime());
$sdate_dd = date('d', $startTime);
$sdate_mm = date('m', $startTime);
$sdate_yy = date('Y', $startTime);
$sdate_hh = date('H', $startTime);
$sdate_ii = date('i', $startTime);
$endTime = strtotime($when[0]->getEndTime());
$edate_dd = date('d', $endTime);
$edate_mm = date('m', $endTime);
$edate_yy = date('Y', $endTime);
$edate_hh = date('H', $endTime);
$edate_ii = date('i', $endTime);
<form method="post"
action="<?php echo htmlentities($_SERVER['PHP_SELF']); ?>">
<input type="hidden" name="id" value="<?php echo $_GET['id']; ?>">
Event title: <br/>
<input name="title" type="text" size="15"
value="<?php echo $title; ?>"/><p/>
Start date (dd/mm/yyyy): <br/>
<input name="sdate_dd" type="text" size="2"
value="<?php echo $sdate_dd; ?>" />
<input name="sdate_mm" type="text" size="2"
value="<?php echo $sdate_mm; ?>"/>
<input name="sdate_yy" type="text" size="4"
value="<?php echo $sdate_yy; ?>"/><p/>
Start time (hh:mm): <br/>
<input name="sdate_hh" type="text" size="2"
value="<?php echo $sdate_hh; ?>"/>
<input name="sdate_ii" type="text" size="2"
value="<?php echo $sdate_ii; ?>"/><br/>
End date (dd/mm/yyyy): <br/>
<input name="edate_dd" type="text" size="2"
value="<?php echo $edate_dd; ?>" />
<input name="edate_mm" type="text" size="2"
value="<?php echo $edate_mm; ?>" />
<input name="edate_yy" type="text" size="4"
value="<?php echo $edate_yy; ?>" /><p/>
End time (hh:mm): <br/>
<input name="edate_hh" type="text" size="2"
value="<?php echo $edate_hh; ?>" />
<input name="edate_ii" type="text" size="2"
value="<?php echo $edate_ii; ?>" /><br/>
<input name="submit" type="submit" value="Save" />
</form>
<?php
} else {
// if form submitted
// validate input
if (empty($_POST['id'])) {
die('ERROR: Missing event ID');
if (empty($_POST['title'])) {
die('ERROR: Missing title');
if (!checkdate($_POST['sdate_mm'], $_POST['sdate_dd'], $_POST['sdate_yy'])) {
die('ERROR: Invalid start date/time');
if (!checkdate($_POST['edate_mm'], $_POST['edate_dd'], $_POST['edate_yy'])) {
die('ERROR: Invalid end date/time');
$title = htmlentities($_POST['title']);
$start = date(DATE_ATOM, mktime($_POST['sdate_hh'], $_POST['sdate_ii'],
0, $_POST['sdate_mm'], $_POST['sdate_dd'], $_POST['sdate_yy']));
$end = date(DATE_ATOM, mktime($_POST['edate_hh'], $_POST['edate_ii'],
0, $_POST['edate_mm'], $_POST['edate_dd'], $_POST['edate_yy']));
// get existing event record
// update event attributes
// save changes to server
try {
feeds/default/private/full/' . $_POST['id']);
$event->title = $gcal->newTitle($title);
$when = $gcal->newWhen();
$when->startTime = $start;
$when->endTime = $end;
$event->when = array($when);
$event->save();
die("Error: " . $e->getResponse());
echo 'Event successfully modified!';
</body>
</html>
类似于 , 也通过 GET 方法取得事件标识符。然后通过 getCalendarEventEntry() 方法取得事件的详细内容,然后使用它预先填充 Web 表单。用户可以在表单中修改并提交事件的详细内容;提交后,脚本联系 Calendar Data API,构造修改后的 <entry>,使它包含新的事件详细内容,最后使用 save() 方法把修改保存到服务器上。 |
