3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
| public void addComponent(XUIComponent component) throws XUITypeFormatException {
if(component instanceof XUIBasicDialog
|| component instanceof XUIOpenFileDialog
|| component instanceof XUICustomDialog
|| component instanceof XUIMenuBar
|| component instanceof XUIPanel
|| component instanceof XUISplitPanel
|| component instanceof XUITabbedPanel
|| component instanceof XUISaveFileDialog) {
// get the node
XUINode node = component.getNodeRepresentation();
if(!(component instanceof XUIMenuBar)) {
int x = Integer.parseInt(node.getAttributeValue("x"));
int y = Integer.parseInt(node.getAttributeValue("y"));
int width = Integer.parseInt(node.getAttributeValue("width"));
int height = Integer.parseInt(node.getAttributeValue("height"));
// can't add dialogs so need to check for type here.
|| component instanceof XUISaveFileDialog) ; // nothing
else {
// check to make sure it fits within the grid.
Dimension localGrid = this.getGrid();
if(width > localGrid.getWidth() || height >
localGrid.getHeight()) {
throw new XUITypeFormatException(node.getName()
+ " (id: " + node.getAttributeID()
+ ") must be within this window's grid width and"
+ "height (w: " + localGrid.getWidth()
+ " + h: " + localGrid.getHeight() + ")");
Rectangle rect = new Rectangle(y, x, width, height);
component.getPeer().setEnabled(true);
frame.getContentPane().add(component.getPeer(), rect);
// for mapping components to the regions they occupy
childComponentMappings.put(component, rect);
component.setComponentLocation(x, y);
} else {
// do specifics for a menubar
frame.setJMenuBar((JMenuBar)component.getPeer());
frame.invalidate();
frame.validate();
// add the component's node
int level = win.getLevel();
node.setLevel(++level);
if(win.getParent() == null)
win.addChildNode(node);
} else {
StringBuffer sb = new StringBuffer();
sb.append("Type not supported in XUIWindow. ");
sb.appen("The following types are supported:\n");
for(int i = 0; i < supportedComponents.size(); i++) {
String s = (String)supportedComponents.get(i);
sb.append("- " + s + "\n");
throw new XUITypeFormatException(sb.toString());
