3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
92
93
94
95
96
97
98
99
100
101
102
103
104
105
106
107
108
109
110
111
112
113
114
115
116
117
118
| <?xml version="1.0" encoding="UTF-8"?>
<!-- Generated by The Purnama Project XUI API version 0.5 -->
<xui:XUI xmlns:xui="http://xml.bcit.ca/PurnamaProject/2003/xui"
xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
xsi:schemaLocation="http://xml.bcit.ca/PurnamaProject/2003/xui ../../xui.xsd"
id="http://xml.bcit.ca/PurnamaProject/examples/XUIWebBrowser">
<xui:Window id="window_0" name="XUI Web Browser" x="200" y="20" width="800"
height="600" visible="true">
<xui:GridLayout width="1" height="1"></xui:GridLayout>
<xui anel x="0" y="0" width="1" height="1" id="panel_0" name="main panel"
idref="window_0">
<xui:GridLayout width="8" height="8"></xui:GridLayout>
<xui:HypertextPane x="1" y="0" width="8" height="7" id="hyper_0"
uri="http://www.w3c.org"></xui:HypertextPane>
<xui:Button x="0" y="0" width="1" height="1" id="button_0" label="Back"
enabled="true" orientation="horizontal"></xui:Button>
<xui:Button x="0" y="3" width="1" height="1" id="button_1" label="Home"
<xui:Button x="0" y="7" width="1" height="1" id="button_2"
label="Forward" enabled="true" orientation="horizontal"></xui:Button>
</xui anel>
<!-- For opening files. Only want to see html files -->
<xui:OpenFileDialog x="10" y="10" width="400" height="300"
id="filedialog_0" idref="window_0" visible="false">
<xui:Filter>html</xui:Filter>
<xui:Filter>htm</xui:Filter>
</xui:OpenFileDialog>
<!-- For saving files. Only want to save html files -->
<xui:SaveFileDialog x="10" y="10" width="400" height="300"
id="savedialog_0" idref="window_0" visible="false">
</xui:SaveFileDialog>
<!-- Ask the user if they really want to quit -->
<xui:CustomDialog x="200" y="200" width="320" height="160"
id="customdialog_1" idref="window_0" name="Exit Purnama Browser"
modal="true" visible="false">
<xui anel x="0" y="0" width="1" height="1" id="panel_2"
name="Quit Panel" idref="customdialog_0">
<xui:GridLayout width="5" height="4"></xui:GridLayout>
<xui abel id="label_0" x="1" y="1" width="3" height="1"
justified="center" text="Do you really want to exit?"></xui abel>
<xui:Button x="2" y="1" width="1" height="1" id="button_3"label="Yes"
<xui:Button x="2" y="3" width="1" height="1" id="button_4" label="No"
</xui anel>
</xui:CustomDialog>
<!-- For displaying the bookmarks -->
<xui:CustomDialog x="100" y="100" width="300" height="300"
id="customdialog_0" idref="window_0" name="Bookmarks" modal="false"
visible="false">
<xui anel x="0" y="0" width="1" height="1" id="panel_1"
name="bookmarks panel" idref="customdialog_0">
<xui ist x="0" y="0" width="1" height="1" id="list_0" enabled="true"
itemSelected="0" scrolling="vertical">
<xui istItem>http://www.w3c.org</xui istItem>
<xui istItem>http://www.agentcities.org</xui istItem>
<xui istItem>http://www.apache.org</xui istItem>
<xui istItem>http://www.gnu.org</xui:ListItem>
</xui:List>
</xui anel>
</xui:CustomDialog>
<!-- The menu bar with pop-up menu items too -->
<xui:MenuBar id="menuBar_0" idref="window_0">
<xui:Menu id="menu_0" idref="menuBar_0" enabled="true"
isPopupMenu="false" isSubMenu="false" label="File">
<xui:MenuItem id="mi_1" idref="menu_0" enabled="true" label="Open URL"
checked="false">
<xui:Shortcut keyCode="F" keyModifier1="ALT"></xui:Shortcut>
</xui:MenuItem>
<xui:MenuItem id="mi_0" idref="menu_0" enabled="true" label="Save"
checked="false">
</xui:MenuItem>
<xui:MenuItem id="mi_2" idref="menu_0" enabled="true" label="Exit"
checked="false">
<xui:Shortcut keyCode="X" keyModifier1="CTRL"></xui:Shortcut>
</xui:MenuItem>
</xui:Menu>
<xui:Menu id="menu_1" idref="menuBar_0" enabled="true"
isPopupMenu="false" isSubMenu="false" label="Bookmarks">
<xui:MenuItem id="mi_3" idref="menu_1" enabled="true"
label="Add Bookmark" checked="false">
<xui:Shortcut keyCode="D" keyModifier1="CTRL"></xui:Shortcut>
</xui:MenuItem>
<xui:MenuItem id="mi_4" idref="menu_0" enabled="true"
label="Manage Bookmarks" checked="false">
<xui:Shortcut keyCode="M" keyModifier1="CTRL"></xui:Shortcut>
</xui:MenuItem>
</xui:Menu>
<xui:Menu id="menu_2" idref="hyper_0" enabled="true" isPopupMenu="true"
isSubMenu="false" label="">
<xui:MenuItem id="mi_5" idref="menu_2" enabled="true"
label="Save As ..." checked="false"></xui:MenuItem>
<xui:MenuItem id="mi_6" idref="menu_2" enabled="true" label=" revious"
<xui:MenuItem id="mi_7" idref="menu_2" enabled="true" label="Next"
<xui:MenuItem id="mi_8" idref="menu_2" enabled="true" label="Home"
<xui:MenuItem id="mi_9" idref="menu_2" enabled="true" label="Bookmark"
</xui:Menu>
</xui:MenuBar>
</xui:Window>
<!-- The library (model) code that drives the user interface -->
<xui:Resource type="java" class="BrowserModel" uri="BrowserModel.jar"/>
</xui:XUI>
