基于 OAuth 安全协议的 Java 应用编程(4)示例更新
使用 OAuth Access Token 访问 Google 服务接下来,我们使用上一节获得的 Access Token 设置 Google Service 的 OAuth 认证参数,然后从 Google Service 获取该用户的 Calendar 信息:
3
4
| OAuthParameters para = new OAuthParameters();
para.setOAuthConsumerKey("www.example.com");
para.setOAuthToken(accessToken);
googleService.setOAuthCredentials(para, signer);
清单 1 是完整的示例代码,供读者参考。
清单 1. 基于 OAuth 认证的 Google Service 消费方实现1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
92
93
94
95
96
97
98
99
100
101
102
103
104
105
106
107
108
109
110
111
112
113
114
115
116
117
118
119
120
121
122
123
124
125
126
127
128
129
130
131
132
133
134
135
136
137
138
139
140
141
| import java.util.Collection;
import java.util.Map;
import net.oauth.OAuth;
import net.oauth.OAuthAccessor;
import net.oauth.OAuthConsumer;
import net.oauth.client.OAuthClient;
public class DesktopClient {
private final OAuthAccessor accessor;
private OAuthClient oauthClient = null;
public DesktopClient(OAuthConsumer consumer) {
accessor = new OAuthAccessor(consumer);
public OAuthClient getOAuthClient() {
return oauthClient;
public void setOAuthClient(OAuthClient client) {
this.oauthClient = client;
//get the OAuth access token.
public String getAccessToken(String httpMethod,
Collection<? extends Map.Entry> parameters) throws Exception {
getOAuthClient().getRequestTokenResponse(accessor, null,parameters);
String authorizationURL = OAuth.addParameters(
accessor.consumer.serviceProvider.userAuthorizationURL,
OAuth.OAUTH_TOKEN, accessor.requestToken);
//Launch the browser and redirects user to authorization URL
Runtime.getRuntime().exec("rundll32 url.dll,FileProtocolHandler "
+ authorizationURL);
//wait for user's authorization
System.out.println("Please authorize your OAuth request token. "
+ "Once that is complete, press any key to continue...");
System.in.read();
oauthClient.getAccessToken(accessor, null, null);
return accessor.accessToken;
import java.net.URL;
import java.security.KeyFactory;
import java.security.PrivateKey;
import java.security.spec.EncodedKeySpec;
import java.security.spec.PKCS8EncodedKeySpec;
import com.google.gdata.client.GoogleService;
import com.google.gdata.client.authn.oauth.OAuthParameters;
import com.google.gdata.client.authn.oauth.OAuthRsaSha1Signer;
import com.google.gdata.client.authn.oauth.OAuthSigner;
import com.google.gdata.data.BaseEntry;
import com.google.gdata.data.BaseFeed;
import com.google.gdata.data.Feed;
import net.oauth.OAuthMessage;
import net.oauth.OAuthServiceProvider;
import net.oauth.client.httpclient4.HttpClient4;
import net.oauth.example.desktop.MyGoogleService;
import net.oauth.signature.OAuthSignatureMethod;
import net.oauth.signature.RSA_SHA1;
public class GoogleOAuthExample {
//Note, use the private key of your self-signed X509 certificate.
private static final String PRIVATE_KEY = "XXXXXXXX";
public static void main(String[] args) throws Exception {
KeyFactory fac = KeyFactory.getInstance("RSA");
//PRIVATE_KEY is the private key of your self-signed X509 certificate.
EncodedKeySpec privKeySpec = new PKCS8EncodedKeySpec(
OAuthSignatureMethod.decodeBase64(PRIVATE_KEY));
PrivateKey privateKey = fac.generatePrivate(privKeySpec);
OAuthServiceProvider serviceProvider = new OAuthServiceProvider(
//used for obtaining a request token
//"https://www.google.com/accounts/OAuthGetRequestToken",
//used for authorizing the request token
"https://www.google.com/accounts/OAuthAuthorizeToken",
//used for upgrading to an access token
"https://www.google.com/accounts/OAuthGetAccessToken");
OAuthConsumer oauthConsumer = new OAuthConsumer(null
, "lszhy.weebly.com" //consumer key
, "hIsGnM+T4+86fKNesUtJq7Gs" //consumer secret
, serviceProvider);
oauthConsumer.setProperty(OAuth.OAUTH_SIGNATURE_METHOD, OAuth.RSA_SHA1);
oauthConsumer.setProperty(RSA_SHA1.PRIVATE_KEY, privateKey);
DesktopClient client = new DesktopClient(oauthConsumer);
client.setOAuthClient(new OAuthClient(new HttpClient4()));
Collection<? extends Map.Entry> parameters =
OAuth.newList("scope","http://www.google.com/calendar/feeds/");
String accessToken = client.getAccessToken(OAuthMessage.GET,parameters);
//Make an OAuth authorized request to Google
// Initialize the variables needed to make the request
URL feedUrl = new URL(
"http://www.google.com/calendar/feeds/default/allcalendars/full");
System.out.println("Sending request to " + feedUrl.toString());
System.out.println();
GoogleService googleService = new GoogleService("cl", "oauth-sample-app");
OAuthSigner signer = new OAuthRsaSha1Signer(MyGoogleService.PRIVATE_KEY);
// Set the OAuth credentials which were obtained from the step above.
para.setOAuthConsumerKey("lszhy.weebly.com");
// Make the request to Google
BaseFeed resultFeed = googleService.getFeed(feedUrl, Feed.class);
System.out.println("Response Data:");
System.out.println("==========================================");
System.out.println("|TITLE: " + resultFeed.getTitle().getPlainText());
if (resultFeed.getEntries().size() == 0) {
System.out.println("|\tNo entries found.");
} else {
for (int i = 0; i < resultFeed.getEntries().size(); i++) {
BaseEntry entry = (BaseEntry) resultFeed.getEntries().get(i);
System.out.println("|\t" + (i + 1) + ": "
+ entry.getTitle().getPlainText());
