使用 HTML5 中的 Microdata 增强 Web 应用程序的语义(4)
添加 People Microdata 到你的 Web 页面中这里看一个添加 People Microdata 到你的 Web 页面中的例子,首先看一个不添加任何 Microdata 属性的例子。
清单 4
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
<section>
<img width="204" height="250"
       src="//diveintohtml5.org/examples/2000_05_mark.jpg"
       alt="[Mark Pilgrim, circa 2000]">
<h1>Contact Information</h1>
<dl>
   <dt>Name</dt>
   <dd>Mark Pilgrim</dd>
   <dt>Position</dt>
   <dd>Developer advocate for Google, Inc.</dd>
   <dt>Mailing address</dt>
   <dd>
      100 Main Street<br>
      Anytown, PA 19999<br>
      USA
   </dd>
</dl>
<h1>My Digital Footprints</h1>
<ul>
   <li><a href="http://diveintomark.org/">weblog</a></li>
   <li><a href="http://www.google.com/profiles/pilgrim">Google profile</a></li>
<li><a href="http://www.reddit.com/user/MarkPilgrim">Reddit.com profile</a></li>
   <li><a href="http://www.twitter.com/diveintomark">Twitter</a></li>
</ul>
</section>
首先要做的是声明一个词汇表,和它的使用范围。需要做的是在包含所有数据的最外层标识中添加 itemscope 和 itemtype 属性,在这个例子中那个最外层标识是 <section> 元素:
<section itemscope itemtype="http://data-vocabulary.org/Person">
现在可以从 http://data-vocabulary.org/Person 词汇表中定义 Microdata 属性。你可以打开 http://data-vocabulary.org/Person 去查看属性的列表,Microdata 规范并不要求这么做,不过为了清晰每个属性的含义,这里加上这个属性。毕竟为了开发人员能够使用这个词汇表,你需要记载你的词汇表。Table2 列出了 Person 词汇表的属性:
表 2. Person 词汇表 Property  Description name Name nickname Nickname photo An image link title The person ’ s title (for example, “Financial Manager”) role The person ’ s role (for example, “Accountant”) url Link to a web page, such as the person ’ s home page affiliation The name of an organization with which the person is associated (for example, an employer) friend Identifies a social relationship between the person described and another person contact Identifies a social relationship between the person described and another person acquaintance Identifies a social relationship between the person described and another person address The location of the person (can have the subproperties street-address, locality, region, postal-code, and country-name)
这里例子中的第一个元素是我的图片,通常它用 <img> 元素标识,为了声明 <img> 元素标识的是我的图片,只需要给 <img> 添加 itemprop="photo":
清单 5
3
<img itemprop="photo" width="204" height="250"
从表 1 中可以看出,<img> 的属性值就是 src 属性,每个 <img> 元素都有一个 src 属性,并且 src 通常是一个 url。
这里 <img> 元素并不是单独的,它是 <section> 元素的一个子元素,我们刚在 <section> 中声明了 itemscope 属性。Microdata 重用元素的父子关系来定义 Microdata 属性的范围(scoping)。简单地说,<section> 代表一个人(person),任何在 <section> 能找到的子元素都是人(preson)的属性。可以这么认为,将 <section> 作为句子的主语,itemprop 属性作为句子的谓语,而 Microdata 属性值代表句子的宾语:
清单 6
3
This person [explicit, from <section itemscope itemtype="...">]
is pictured at [explicit, from <img itemprop="photo">]
http://diveintohtml5...000_05_mark.jpg [implicit, from <img src> attribute]
主语只需要定义一次,通过在最外层的 <section> 元素中添加 itemscope 和 itemtype 属性完成,谓语通过在 <img> 元素中添加 itemprop="photo"属性完成,宾语不需要特殊的标识,因为 Table1 中规定了 <img> 元素的属性值是 src 属性。
接下来看到标题 <h1> 标签和 <dl> 列表标签,<h1> 或 <dl> 都必须要被 Microdata 标识,并不是每一个 HTML 标签都需要一个 Microdata 属性,Microdata 用来描述属性本身,而不是包含属性的标题或列表。<h1> 并不是一个属性,它只是一个标题,同样,<dl> 表示"name"只是一个标签,不是一个属性:
清单 7
3
4
<dl>
   <dt>Name</dt>
哪里才是真正的信息呢?在 <dd> 元素中,这里才是需要添加 itemprop 属性的地方。使用哪个属性呢?正是 name 属性。那么属性值呢?就是在 <dd> 元素中的文本内容。它需要被标识起来吗?根据 Table1 的规定,<dd> 元素不需要特殊的处理,所以它的属性值只是它包含的纯文本:
<dd itemprop="name">Mark Pilgrim</dd>
接下来的两个属性比较棘手,先看使用 Microdata 前的代码片段:
<dt>Position</dt>
看一下 Person 词汇表的定义,你会发现文本“Developer advocate for Google, Inc.”实际上包含两个属性:title(“Developer advocate”)和 affiliation(“Google, Inc”)。怎么在 Microdata 中表示这两个属性呢?答案是你不能,Microdata 没有办法将文本分为多个属性,你不能说前 18 个字符是一个 Microdata 属性,剩下的 12 个字符是另外一个 Microdata 属性。
想象一下,你想让前 18 个字符用一种风格,剩下 12 个字符用另一种风格,CSS 可以做到吗?答案也是不能。不过你可以把前 18 个字符内嵌到一个元素中,像 <span>,剩下 12 个字符内嵌到另一个 <span> 中,然后对不同的 <span> 使用不同的 CSS 样式。
这种技术同样适用于 Microdata,这里有两段不同的信息:title 和 affiliation,如果分别将两段信息内嵌到不同的 <span> 元素中,你可以声明每个 <span> 为独立的 Microdata 属性。
清单 8
3
<dt>Position</dt>
<dd><span itemprop="title">Developer advocate</span> for
   <span itemprop="affiliation">Google, Inc.<span></dd>
同样这个技术也可以用于组合街道地址。Person 词汇表定义了 address 属性,而这个属性本身也是一个词汇表,并且定义自己的属性(properties):street-address, locality, region, postal-code, 和 country-name。
你可能对用点标识对象和属性的方式很熟悉,想象这样的关系:
  • Person
  • Person.address
  • Person.address.street-address
  • Person.address.locality
  • Person.address.region
  • Person.address.postal-code
  • Person.address.country-name
这个例子中,所有的街道地址信息都包含在一个 <dd> 元素中。标识 address 属性比较简单,只需要在 <dd> 元素上添加 itemprop 属性。
<dd itemprop="address">
但是要注意,address 本身也是一个 Microdata 项,所以我们需要还需要定义 itemscope 和 itemtype 属性:
清单 9
3
<dd itemprop="address" itemscope
itemtype="http://data-vocabulary.org/Address">
Address 同样遇到前面 title 和 affiliation 的问题,address 是一长串的字符串,但是我们想把它分割成几部分。解决办法是一样,我们把不同的部分内嵌到不同的 <span> 中,然后在 <span> 上声明不同的 Microdata 属性:
清单 10
3
4
5
6
7
8
9
   <span itemprop="street-address">100 Main Street</span><br>
   <span itemprop="locality">Anytown</span>,
   <span itemprop="region">PA</span>
   <span itemprop="postal-code">19999</span>
   <span itemprop="country-name">USA</span>
</dd>
</dl>
还有一个需要关注的就是一系列的 URL。Person 词汇表有个叫做 url 的属性,url 的定义很宽松,可以是任何你想跟一个人关联的 url:一个博客,一个照片。
值得注意的是一个人可以有很多的 url 属性。从技术上讲,任何属性都可以出现多次,比如,你可以拥有两张图像,每个用不同的 url 表示。这里我们要列出四个不同的 url。在 HTML 中,它是一系列 url 的列表:四个 <a> 元素,每个在 <li> 元素中。在 Microdata 中,每个 <a> 元素有一个 itemprop="url"属性:
清单 11
3
4
5
6
7
8
9
10
11
<ul>
        itemprop="url">weblog</a></li>
        itemprop="url">Google profile</a></li>
        itemprop="url">Reddit.com profile</a></li>
        itemprop="url">Twitter</a></li>
</ul>
根据表 1 知道,<a> 元素需要特别处理。它的 Microdata 属性值是 href 属性,而不是子元素的文本内容。
