我用MAX+plus II manager 综合的时候出现了一个问题,only one clock enable singal can be defined for a flipflop 什么意思谁能提醒一下。 LIBRARY IEEE; USE IEEE.STD_LOGIC_1164.ALL; USE IEEE.STD_LOGIC_ARITH.ALL; USE IEEE.STD_LOGIC_UNSIGNED.ALL; ENTITY second1 IS PORT(clk, set, reset : IN STD_LOGIC; s1 : IN STD_LOGIC_VECTOR(7 DOWNTO 0); sec : BUFFER STD_LOGIC_VECTOR(7 DOWNTO 0); ensec : OUT STD_LOGIC); END; ARCHITECTURE one OF second1 IS BEGIN PROCESS(clk,reset,set,s1) BEGIN IF reset = '0' THEN sec<="00000000"; ELSIF set = '0' THEN sec<=s1; ELSIF clk'EVENT AND clk='1' THEN IF sec=59 THEN sec<="00000000" ;ensec<='1'; ELSE sec<=sec+1; ensec<='0'; END IF; END IF; END PROCESS; END;
