发个乘法器的例子,供大家学习
发个乘法器的例子,供大家学习
-- DESCRIPTION   :  Signed mulitplier:
--                  A (A) input width : 4
--                  B (B) input width : 4
--                  Q (data_out) output width : 7
-- Download from :  http://www.pld.com.cn
library IEEE;
use IEEE.std_logic_1164.all;
entity one_bit_adder is
 port (
  A: in STD_LOGIC;
  B: in STD_LOGIC;
  C_in: in STD_LOGIC;
  S: out STD_LOGIC;
  C_out: out STD_LOGIC
end one_bit_adder;
architecture one_bit_adder of one_bit_adder is
begin
 S <= A xor B xor C_in;
 C_out <= (A and B) or (C_in and (A xor B));
end one_bit_adder;
library IEEE;
entity multi is
 port (
  A: in STD_LOGIC_VECTOR (3 downto 0);
  B: in STD_LOGIC_VECTOR (3 downto 0);
  data_out: out STD_LOGIC_VECTOR (6 downto 0)
end multi;
architecture multi_arch of multi is
signal A_MULT_B0: STD_LOGIC_VECTOR (2 downto 0);
signal A_MULT_B1: STD_LOGIC_VECTOR (2 downto 0);
signal A_MULT_B2: STD_LOGIC_VECTOR (2 downto 0);
signal S_TEMP1: STD_LOGIC_VECTOR (1 downto 0);
signal S_TEMP2: STD_LOGIC_VECTOR (1 downto 0);
signal C_TEMP : STD_LOGIC_VECTOR (6 downto 0);
signal C0_out_B0, C1_out_B0, C2_out_B0 : STD_LOGIC;
signal C0_out_B1, C1_out_B1, C2_out_B1 : STD_LOGIC;
signal ZERO: STD_LOGIC;
component one_bit_adder
 port (
  A: in STD_LOGIC;
  B: in STD_LOGIC;
  C_in: in STD_LOGIC;
  S: out STD_LOGIC;
end component;
begin
 U_0_0 : one_bit_adder port map (A => A_MULT_B0(1), B => A_MULT_B1(0), C_in => ZERO, S => C_TEMP(1), C_out => C0_out_B0);
 U_0_1 : one_bit_adder port map (A => A_MULT_B0(2), B => A_MULT_B1(1), C_in => C0_out_B0, S => S_TEMP1(0), C_out => C1_out_B0);
 U_0_2 : one_bit_adder port map (A => ZERO, B => A_MULT_B1(2), C_in => C1_out_B0, S => S_TEMP1(1), C_out => C2_out_B0);
 U_1_0 : one_bit_adder port map (A => A_MULT_B2(0), B => S_TEMP1(0), C_in => ZERO, S => C_TEMP(2), C_out => C0_out_B1);
 U_1_1 : one_bit_adder port map (A => A_MULT_B2(1), B => S_TEMP1(1), C_in => C0_out_B1, S => S_TEMP2(0), C_out => C1_out_B1);
 U_1_2 : one_bit_adder port map (A => A_MULT_B2(2), B => C2_out_B0, C_in => C1_out_B1, S => S_TEMP2(1), C_out => C2_out_B1);
 A_MULT_B0(0) <= A (0) and B (0);
 A_MULT_B0(1) <= A (1) and B (0);
 A_MULT_B0(2) <= A (2) and B (0);
 A_MULT_B1(0) <= A (0) and B (1);
 A_MULT_B1(1) <= A (1) and B (1);
 A_MULT_B1(2) <= A (2) and B (1);
 A_MULT_B2(0) <= A (0) and B (2);
 A_MULT_B2(1) <= A (1) and B (2);
 A_MULT_B2(2) <= A (2) and B (2);
 ZERO <= '0';
 C_TEMP(0) <= A_MULT_B0(0);
 C_TEMP(4 downto 3) <=  S_TEMP2(1 downto 0);
 C_TEMP(5) <= C2_out_B1;
 C_TEMP(6) <= A(3) xor B(3);
 data_out <= C_TEMP;
end multi_arch;
这个版主不太冷 =========================== 我的中电网博客:http://blog.chinaecnet.com/u/20/index.htm
[求助]回复:(caopengly)发个乘法器的例子,供大家学习
能加点注释,说明算法思想吗 ?
这种方法就是分解成许多
然后接起来,
当然也可以用系统带的*指令。
