8位乘法器,移位加法器实现(VHDL)
8位乘法器,移位加法器实现(VHDL)
网上找到的 8位乘法器,移位加法器实现 的 VHDL代码
不知道移位加法器是什么东西?我看这个程序看了好久也没有感觉出来!
library ieee;
use ieee.std_logic_1164.all;
use ieee.std_logic_unsigned.all;
entity multi8x8 is
 port(clk, start: in std_logic;
 a, b: in std_logic_vector(7 downto 0);
 ariend: out std_logic;
 dout: out std_logic_vector(15 downto 0));
end entity;
architecture a of multi8x8 is
 component arictl is
  ariend, restall, clkout: out std_logic);
 end component;
 component andarith is
  port(din: in std_logic_vector(7 downto 0);
  abin: in std_logic;
  dout: out std_logic_vector(7 downto 0));
 end component;
 component sreg8b is
  port(clk, load: in std_logic;
  qb: out std_logic);
 end component;
 component reg16b is
  port(clk, clr: in std_logic;
  d: in std_logic_vector(8 downto 0);
  q: out std_logic_vector(15 downto 0));
 end component;
 component adder8b is
  port(cin: in std_logic;
  s: out std_logic_vector(7 downto 0);
  cout: out std_logic);
 end component;
 signal s1, s2, s3, s4: std_logic;
 signal s5: std_logic_vector(7 downto 0);
 signal s6: std_logic_vector(8 downto 0);
 signal s7: std_logic_vector(15 downto 0);
begin
 dout<=s7; s1<='0';
 u1: arictl
 port map(clk=>clk, start=>start, clkout=>s2, restall=>s3, ariend=>ariend);
 u2: sreg8b
 port map(clk=>s3, load=>s2, din=>a, qb=>s4);
 u3: andarith
 port map(abin=>s4, din=>b, dout=>s5);
 u4: adder8b
 port map(cin=>s1, a=>s7(15 downto 8), b=>s5, s=>s6(7 downto 0), cout=>s6(8));
 u5: reg16b
 port map(clk=>s2, clr=>s3, d=>s6, q=>s7);
 dout<=s7; s1<='0';
end architecture;
library ieee;
entity arictl is
 ariend, clkout, restall: out std_logic);
end entity;
architecture a of arictl is
 signal count: std_logic_vector(3 downto 0);
begin
 restall<=start;
 process(clk, start)is
 begin
  if start='1' then count<="0000";
  elsif (clk'event and clk='1') then
   if count<8 then
    count<=count+'1';
   end if;
  end if;
 end process;
 process(clk, count, start)is
 begin
  if start='0' then
   if count<8 then
    clkout<=clk;
    ariend<='0';
   else
    clkout<=clk;
    ariend<='1';
   end if;
  end if;
 end process;
end architecture;
library ieee;
entity sreg8b is
 qb: out std_logic);
end entity;
architecture a of sreg8b is
 signal temp: std_logic_vector(7 downto 0);
begin
 process(clk, load) is
 begin
  if(clk'event and clk='1')then
   if load='1' then
    temp<=din;
   else
    temp(6 downto 0)<=temp(7 downto 1);
   end if;
  end if;
 end process;
 qb<=temp(0);
end architecture;
library ieee;
entity andarith is
 abin: in std_logic;
end entity;
architecture a of andarith is
begin
 process(abin, din)
 begin
  for i in 0 to 7 loop
   dout(i)<=din(i) and abin;
  end loop;
 end process;
end architecture;
library ieee;
entity reg16b is
end entity;
architecture a of reg16b is
 signal r16s: std_logic_vector(15 downto 0);
begin
 process(clk, clr) is
 begin
  if clr='1' then r16s<="0000000000000000";
  elsif(clk'event and clk='1') then
   r16s(6 downto 0)<=r16s(7 downto 1);
   r16s(15 downto 7)<=d;
  end if;
 end process;
 q<=r16s;
end architecture;
library ieee;
entity adder8b is
end entity;
architecture art of adder8b is
 component adder4b is
  port(c4: in std_logic;
  a4, b4: in std_logic_vector(3 downto 0);
  s4: out std_logic_vector(3 downto 0);
  co4: out std_logic);
 end component;
 signal sc: std_logic;
begin
 u1: adder4b
 port map(c4=>cin, a4=>a(3 downto 0), b4=>b(3 downto 0),
 s4=>s(3 downto 0), co4=>sc);
 u2: adder4b
 port map(c4=>sc, a4=>a(7 downto 4), b4=>b(7 downto 4),
 s4=>s(7 downto 4), co4=>cout);
end architecture;
library ieee;
entity adder4b is
end entity;
architecture art of adder4b is
 signal s5: std_logic_vector(4 downto 0);
 signal a5, b5: std_logic_vector(4 downto 0);
begin
 a5<='0'&a4;
 b5<='0'&b4;
 s5<=a5+b5+c4;
 s4<=s5(3 downto 0);
 co4<=s5(4);
end architecture;
没有人顶
[em08]
