# 2007.10.05 12:51:32 (*) Running Generator Program for cpu_0 # 2007.10.05 12:51:34 (*) IP functional simulation model enabled: Uncheck System Generation Simulation box for faster generation if HDL Simulation not required. 'e:\altera\kits\nios2_60\components\altera_nios2\eperl' 不是内部或外部命令,也不是可运行的程序 或批处理文件。 Error: Generator program for module 'cpu_0' did NOT run successfully. generator cmd was 'e:/altera/quartus60//bin/perl561/bin/perl -Ie:/altera/quartus60/sopc_builder/bin -Ie:/altera/quartus60/sopc_builder/bin/europa -Ie:/altera/quartus60/sopc_builder/bin/perl_lib -I. -Ie:/altera/kits/nios2_60/components/altera_nios2 -Ie:/altera/kits/nios2_60/components/altera_nios_dev_board_stratix_1s10_es -Ie:/altera/kits/nios2_60/components/altera_nios_dev_board_stratix_2s60_es -Ie:/altera/quartus60/sopc_builder/components/altera_avalon_adapter_slave_y -Ie:/altera/kits/nios2_60/components/altera_nios_custom_instr_endian_converter -Ie:/altera/quartus60/sopc_builder/components/amd_avalon_am29lv128m_flash -Ie:/altera/kits/nios2_60/components/altera_nios_dev_kit_stratix_edition_sram -Ie:/altera/quartus60/sopc_builder/components/amd_avalon_am29lv065d_flash -Ie:/altera/quartus60/sopc_builder/components/altera_sopc_builder -Ie:/altera/quartus60/sopc_builder/components/altera_avalon_adapter_upstream_pipeline -Ie:/altera/kits/nios2_60/components/altera_nios_dev_board_stratix_1s40 -Ie:/altera/kits/nios2_60/components/altera_nios2 -Ie:/altera/kits/nios2_60/components/altera_nios_dev_board_cyclone_2c35 -Ie:/altera/quartus60/sopc_builder/components/altera_avalon_clock_adapter -Ie:/altera/quartus60/sopc_builder/components/altera_avalon_spi -Ie:/altera/quartus60/sopc_builder/components/altera_avalon_adapter_master_y -Ie:/altera/kits/nios2_60/components/altera_nios_dev_board_stratix_2s60 -Ie:/altera/quartus60/sopc_builder/components/altera_avalon_cfi_flash -Ie:/altera/quartus60/sopc_builder/components/altera_avalon_dma -Ie:/altera/quartus60/sopc_builder/components/altera_avalon_mailbox -Ie:/altera/quartus60/sopc_builder/components/altera_avalon_tri_state_bridge -Ie:/altera/kits/nios2_60/components/altera_nios_eval_board_cyclone_1c12 -Ie:/altera/quartus60/sopc_builder/components/altera_avalon_lan91c111 -Ie:/altera/quartus60/sopc_builder/components/altera_avalon_lcd_16207 -Ie:/altera/kits/nios2_60/components/altera_nios_dev_kit_stratix_edition_sram2 -Ie:/altera/quartus60/sopc_builder/components/altera_avalon_adapter_downstream_pipeline -Ie:/altera/quartus60/sopc_builder/components/altera_avalon_cf -Ie:/altera/kits/nios2_60/components/altera_nios_multiply -Ie:/altera/quartus60/sopc_builder/components/altera_avalon_burst_adapter -Ie:/altera/kits/nios2_60/components/altera_nios_dev_board_cyclone_1c20 -Ie:/altera/quartus60/sopc_builder/components/altera_avalon_pll -Ie:/altera/quartus60/sopc_builder/components/altera_avalon_user_defined_interface -Ie:/altera/kits/nios2_60/components/altera_plugs_library -Ie:/altera/quartus60/sopc_builder/components/altera_avalon_adapter_waitrequest_pipeline -Ie:/altera/quartus60/sopc_builder/components/altera_avalon_cs8900 -Ie:/altera/quartus60/sopc_builder/components/altera_avalon_cy7c1380_ssram -Ie:/altera/quartus60/sopc_builder/components/altera_avalon_endian_adapter -Ie:/altera/kits/nios2_60/components/altera_nios_dev_board_stratix_1s10 -Ie:/altera/quartus60/sopc_builder/components/altera_avalon_jtag_uart -Ie:/altera/kits/nios2_60/components/altera_nios_custom_instr_floating_point -Ie:/altera/quartus60/sopc_builder/components/altera_avalon_asmi -Ie:/altera/quartus60/sopc_builder/components/altera_avalon_onchip_memory -Ie:/altera/quartus60/sopc_builder/components/altera_avalon_onchip_memory2 -Ie:/altera/quartus60/sopc_builder/components/altera_avalon_timer -Ie:/altera/quartus60/sopc_builder/components/altera_avalon_new_sdram_controller -Ie:/altera/kits/nios2_60/components/altera_nios_custom_instr_bitswap -Ie:/altera/kits/nios2_60/components/altera_avalon_c_hardware_accelerator -Ie:/altera/quartus60/sopc_builder/components/altera_avalon_epcs_flash_controller -Ie:/altera/quartus60/sopc_builder/components/altera_avalon_performance_counter -Ie:/altera/quartus60/sopc_builder/components/altera_avalon_sysid -Ie:/altera/quartus60/sopc_builder/components/altera_avalon_mutex -Ie:/altera/quartus60/sopc_builder/components/altera_avalon_uart -Ie:/altera/kits/nios2_60/components/altera_nios_custom_instruction -Ie:/altera/quartus60/sopc_builder/components/altera_avalon_pio e:/altera/kits/nios2_60/components/altera_nios2/cpu_core_select.pl --system_name=cpu32 --target_module_name=cpu_0 --system_directory=E:/altera/quartus60/mm --sopc_directory=e:/altera/quartus60/sopc_builder --sopc_lib_path=E:/altera/quartus60/mm+e:/altera/kits/nios2_60/components+e:/altera/quartus60/sopc_builder/components --generate=1 --verbose=0 --software_only=0 --module_lib_dir=e:/altera/kits/nios2_60/components/altera_nios2 --sopc_quartus_dir=e:/altera/quartus60/ --projectname=gg.quartus ' Error in processing. System NOT successfully generated.
