我对一个过程做如下定义的时候,出来个错误提示 Error (10482): VHDL error at fft_mult.vhd(38): object "a_ext" is used but not declared,显然是因为使用了a_ext ,而a_ext 却在PROCEDURE后定义引起的 PROCEDURE signed_add (signal A,B:IN std_logic_vector; signal C:OUT std_logic_vector) is BEGIN a_ext <= a(WIDTH-1) & a; b_ext <= b(WIDTH-1) & b; sum <= a_ext + b_ext; c <= sum(WIDTH downto 1); END PROCEDURE signed_add; signal a_ext :std_logic_vector(A'high+1 downto 0); signal b_ext :std_logic_vector(A'high+1 downto 0); signal sum :std_logic_vector(A'high+1 downto 0); 为了克服这个问题,我把变量的声明放到PROCEDURE的前面,如下: signal a_ext :std_logic_vector(A'high+1 downto 0); signal b_ext :std_logic_vector(A'high+1 downto 0); signal sum :std_logic_vector(A'high+1 downto 0);  ROCEDURE signed_add (signal A,B:IN std_logic_vector; signal C:OUT std_logic_vector) is BEGIN a_ext <= a(WIDTH-1) & a; b_ext <= b(WIDTH-1) & b; sum <= a_ext + b_ext; c <= sum(WIDTH downto 1); END PROCEDURE signed_add; 却又出来个错误提示:Error (10482): VHDL error at fft_mult.vhd(35): object "A" is used but not declared 天哪,这不是一个先有鸡还是先有蛋的问题吗?请问兄弟们怎么解决? |
