AHDL Function Prototype和VHDL Component Declaration中的声明 参数不一致
AHDL Function Prototype (port name and order also apply to Verilog HDL): FUNCTION lpm_add_sub (cin, dataa[LPM_WIDTH-1..0], datab[LPM_WIDTH-1..0], add_sub, clock, aclr, clken ) WITH (LPM_WIDTH, LPM_REPRESENTATION, LPM_DIRECTION, ONE_INPUT_IS_CONSTANT, LPM_PIPELINE, MAXIMIZE_SPEED, USE_WYS ) RETURNS (result[LPM_WIDTH-1..0], cout, overflow ); VHDL Component Declaration: COMPONENT lpm_add_sub GENERIC (LPM_WIDTH : NATURAL; -- MUST BE GREATER THAN 0 LPM_DIRECTION : STRING := "UNUSED"; LPM_REPRESENTATION : STRING := "SIGNED"; LPM_PIPELINE : NATURAL := 0; LPM_TYPE : STRING := "LPM_ADD_SUB"; LPM_HINT : STRING := "UNUSED" ); PORT (dataa, datab : IN STD_LOGIC_VECTOR(LPM_WIDTH-1 DOWNTO 0); aclr, clock, : IN STD_LOGIC := '0'; clken, add_sub : IN STD_LOGIC := '1'; cin : IN STD_LOGIC := 'Z'; result : OUT STD_LOGIC_VECTOR(LPM_WIDTH-1 DOWNTO 0); cout, overflow : OUT STD_LOGIC ); END COMPONENT; 怎么 AHDL Function Prototype和VHDL Component Declaration中的声明 参数不一致?(见datasheet) 应该以哪个为准呢 ?? |
你应该分析其模块的关系,找到顶层关系接口,然后使用顶层的接口 如function一般只是表达函数关系时调用,在数字电路实现中的单位是模块 我初步估计,应该是  ORT (dataa, datab : IN STD_LOGIC_VECTOR(LPM_WIDTH-1 DOWNTO 0); aclr, clock, : IN STD_LOGIC := '0'; clken, add_sub : IN STD_LOGIC := '1'; cin : IN STD_LOGIC := 'Z'; result : OUT STD_LOGIC_VECTOR(LPM_WIDTH-1 DOWNTO 0); cout, overflow : OUT STD_LOGIC );
这个版主不太冷
我的中电网博客:http://blog.chinaecnet.com/u/20/index.htm |
但他有这么一段介绍: Altera-specific parameter. You must use the LPM_HINT parameter to specify the USE_WYS parameter in VHDL Design Files. Specifies whether to construct an optimized accumulator with the data from the result[] port that cannot be merged with any other logic. Values are "ON" and "OFF" . If omitted, the default is "OFF" . For Cyclone, Cyclone II, HardCopy Stratix, Stratix, and Stratix GX designs, if you turn on the add_sub port, this parameter setting must be "ON" . This parameter is available for Cyclone, Cyclone II, APEX II, HardCopy Stratix, Mercury, Stratix, and Stratix GX devices only. 使用需要使用 add_sub port,参数
USE_WYS 必须存在的呀? |
You must use the LPM_HINT parameter to specify the USE_WYS parameter in VHDL Design Files 说用LPM_HINT parameter 确定USE_WYS parameter。 具体的你在琢磨琢磨,因为我得到的信息不多。 |
这个版主不太冷
You must use the LPM_HINT param...
"LPM_HINT parameter 确定USE_WYS parameter。"就是这个问题,既然LPM_HINT parameter 确定USE_WYS parameter,那USE_WYS parameter。参数必须存在才好设置呀!而 COMPONENT lpm_add_sub GENERIC (LPM_WIDTH : NATURAL; -- MUST BE GREATER THAN 0 LPM_DIRECTION : STRING := "UNUSED"; LPM_REPRESENTATION : STRING := "SIGNED"; LPM_PIPELINE : NATURAL := 0; LPM_TYPE : STRING := "LPM_ADD_SUB"; LPM_HINT : STRING := "UNUSED" ); PORT (dataa, datab : IN STD_LOGIC_..................... 中没有这个参数的描述,所以应该不对,除非刚好设置的参数和这个默认值一致 |
