使用Log4j进行日志操作(2)例子迁移到Log4j
2.2. 迁移到Log4j2.2.1. 客户程序
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
package log4j ;
import java.io.* ;
import java.net.* ;
// add for log4j: import some package
import org.apache.log4j.PropertyConfigurator ;
import org.apache.log4j.Logger ;
import org.apache.log4j.Level ;
* <p> Client With Log4j </p>
* <p> Description: a sample with log4j</p>
* @version 1.0
public class ClientWithLog4j {
    add for log4j: class Logger is the central class in the log4j package.
    we can do most logging operations by Logger except configuration.
    getLogger(...): retrieve a logger by name, if not then create for it.
    static Logger logger = Logger.getLogger
    ( ClientWithLog4j.class.getName () ) ;
     * @param args : configuration file name
    public static void main ( String args [] ) {
        String welcome = null ;
        String response = null ;
        BufferedReader reader = null ;
        PrintWriter writer = null ;
        InputStream in = null ;
        OutputStream out = null ;
        Socket client = null ;
        add for log4j: class BasicConfigurator can quickly configure the package.
        print the information to console.
        PropertyConfigurator.configure ( "ClientWithLog4j.properties" ) ;
        // add for log4j: set the level
//        logger.setLevel ( ( Level ) Level.DEBUG ) ;
        try{
            client = new Socket( "localhost" , 8001 ) ;
            // add for log4j: log a message with the info level
            logger.info ( "Client socket: " + client ) ;
            in = client.getInputStream () ;
            out = client.getOutputStream () ;
        } catch ( IOException e ) {
            // add for log4j: log a message with the error level
            logger.error ( "IOException : " + e ) ;
            System.exit ( 0 ) ;
        try{
            reader = new BufferedReader ( new InputStreamReader ( in ) ) ;
            writer = new PrintWriter ( new OutputStreamWriter ( out ), true ) ;
            welcome = reader.readLine () ;
            // add for log4j: log a message with the debug level
            logger.debug ( "Server says: '" + welcome + "'" ) ;
            logger.debug ( "HELLO" ) ;
            writer.println ( "HELLO" ) ;
            response = reader.readLine () ;
            logger.debug ( "Server responds: '" + response + "'" ) ;
            logger.debug ( "HELP" ) ;
            writer.println ( "HELP" ) ;
            logger.debug ( "Server responds: '" + response + "'") ;
            logger.debug ( "QUIT" ) ;
            writer.println ( "QUIT" ) ;
            // add for log4j: log a message with the warn level
            logger.warn ( "IOException in client.in.readln()" ) ;
            System.out.println ( e ) ;
        try {
            Thread.sleep ( 2000 ) ;
        } catch ( Exception ignored ) {}
2.2.2. 服务器程序
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
92
93
94
95
96
package log4j;
import java.util.* ;
import java.io.* ;
import java.net.* ;
* <p> Server With Log4j </p>
* @version 1.0
public class ServerWithLog4j {
    final static int SERVER_PORT = 8001 ; // this server's port
    ( ServerWithLog4j.class.getName () ) ;
     * @param args
    public static void main ( String args[]) {
        String clientRequest = null ;
        ServerSocket server = null ;
        Socket socket = null ;
        PropertyConfigurator.configure ( "ServerWithLog4j.properties" ) ;
        try{
            server = new ServerSocket ( SERVER_PORT ) ;
            logger.info ( "ServerSocket before accept: " + server ) ;
            logger.info ( "Java server with log4j, on-line!" ) ;
            // wait for client's connection
            socket = server.accept() ;
            logger.info ( "ServerSocket after accept: " + server ) ;
            in = socket.getInputStream() ;
            out = socket.getOutputStream() ;
            logger.error ( "Server constructor IOException: " + e ) ;
            System.exit ( 0 ) ;
        // send welcome string to client
        writer.println ( "Java server with log4j, " + new Date () ) ;
        while ( true ) {
            try {
                // read from client
                clientRequest = reader.readLine () ;
                logger.debug ( "Client says: " + clientRequest ) ;
                if ( clientRequest.startsWith ( "HELP" ) ) {
                    logger.debug ( "OK!" ) ;
                    writer.println ( "Vocabulary: HELP QUIT" ) ;
                else {
                    if ( clientRequest.startsWith ( "QUIT" ) ) {
                        System.exit ( 0 ) ;
                    else {
                        logger.warn ( "Command '"
                        + clientRequest + "' not understood." ) ;
                        writer.println ( "Command '"
                logger.error( "IOException in Server " + e ) ;
                System.exit ( 0 ) ;
2.2.3. 配置文件
2.2.3.1. 客户程序配置文件
3
4
log4j.rootLogger=INFO, A1
log4j.appender.A1=org.apache.log4j.ConsoleAppender
log4j.appender.A1.layout=org.apache.log4j.PatternLayout
log4j.appender.A1.layout.ConversionPattern=%-4r %-5p [%t] %37c %3x - %m%n
2.2.3.2. 服务器程序配置文件
3
4
