Java 优化技术(3)
Java 优化技术(3)
Piece 类更有趣,因为我们需要一种方法来计算 Piece 的排列。我们可以通过先将块沿着其中一个单元的 6 条边旋转,上下翻转,最后再次沿着其中一个单元的 6 条边旋转。正如我们以前提到的,块由 5 个相邻的单元构成。翻转或旋转块就是翻转或旋转其所有单元。因此对于         Cell 对象,我们需要         flip() 和         rotate() 方法。通过相应地更改相邻的边就可以容易地实现翻转和旋转。在         Cell 类的         PieceCell 子类中提供了这些方法,如清单 3 所示。         PieceCell 对象是在         Piece 对象中使用的单元。
清单 3. PieceCell 子类
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
public class PieceCell extends Cell {
  public void flip() {
    Cell buffer = getNeighbour(NORTHEAST);
    setNeighbour(NORTHEAST, getNeighbour(NORTHWEST));
    setNeighbour(NORTHWEST, buffer);
    buffer = getNeighbour(EAST);
    setNeighbour(EAST, getNeighbour(WEST));
    setNeighbour(WEST, buffer);
    buffer = getNeighbour(SOUTHEAST);
    setNeighbour(SOUTHEAST, getNeighbour(SOUTHWEST));
    setNeighbour(SOUTHWEST, buffer);
  public void rotate() {
    // Clockwise rotation
    Cell eastNeighbour = getNeighbour(EAST);
    setNeighbour(EAST, getNeighbour(NORTHEAST));
    setNeighbour(NORTHWEST, getNeighbour(WEST));
    setNeighbour(WEST, getNeighbour(SOUTHWEST));
    setNeighbour(SOUTHWEST, getNeighbour(SOUTHEAST));
    setNeighbour(SOUTHEAST, eastNeighbour);
通过使用         PieceCell 类,我们可以完成         Piece 类的实现。清单 4 向您显示了源代码:
清单 4. Piece 类
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
public class Piece {
  public static final int NUMBEROFCELLS = 5;
  public static final int NUMBEROFPERMUTATIONS = 12;
  private PieceCell[] pieceCells = new PieceCell[NUMBEROFCELLS];
  private int currentPermutation = 0;
  private void rotatePiece() {
    for (int i = 0; i < NUMBEROFCELLS; i++) {
      pieceCells.rotate();
  private void flipPiece() {
      pieceCells.flip();
  public Piece nextPermutation() {
    if (currentPermutation == NUMBEROFPERMUTATIONS)
    switch (currentPermutation%6) {
      case 0:
        // Flip after every 6 rotations
        flipPiece();
        break;
      default:
        rotatePiece();
        break;
    currentPermutation++;
    return this;
  public void resetProcessed() {
      pieceCells.setProcessed(false);
  //Getters and setters have been omitted
