串口的基本知识(程序1)
串口的基本知识(程序1)
  • *软件串口的实现(IO模拟串口)
  • * 波特率:9600    1-8-N
  • * TXD : PC13
  • * RXD : PB14
  • * 使用外部中断对RXD的下降沿进行触发,使用定时器4按照9600波特率进行定时数据接收。
  • * Demo功能: 接收11个数据,然后把接收到的数据发送出去
  • #define OI_TXD        PCout(13)
  • #define OI_RXD        PBin(14)
  • #define BuadRate_9600        100
  • u8 len = 0;        //接收计数
  • u8 USART_buf[11];  //接收缓冲区
  • enum{
  •         COM_START_BIT,
  •         COM_D0_BIT,
  •         COM_D1_BIT,
  •         COM_D2_BIT,
  •         COM_D3_BIT,
  •         COM_D4_BIT,
  •         COM_D5_BIT,
  •         COM_D6_BIT,
  •         COM_D7_BIT,
  •         COM_STOP_BIT,
  • u8 recvStat = COM_STOP_BIT;
  • u8 recvData = 0;
  • void IO_TXD(u8 Data)
  •         u8 i = 0;
  •         OI_TXD = 0;
  •         delay_us(BuadRate_9600);
  •         for(i = 0; i < 8; i++)
  •                 if(Data&0x01)
  •                         OI_TXD = 1;
  •                 else
  •                         OI_TXD = 0;
  •                 Data = Data>>1;
  •         OI_TXD = 1;
  • void USART_Send(u8 *buf, u8 len)
  •         u8 t;
  •         for(t = 0; t < len; t++)
  •                 IO_TXD(buf[t]);
  • void IOConfig(void)
  •         GPIO_InitTypeDef  GPIO_InitStructure;
  •         NVIC_InitTypeDef NVIC_InitStructure;
  •          EXTI_InitTypeDef EXTI_InitStruct;
  •         RCC_APB2PeriphClockCmd(RCC_APB2Periph_AFIO|RCC_APB2Periph_GPIOB|RCC_APB2Periph_GPIOC, ENABLE);         //使能PB,PC端口时钟
  •          //SoftWare Serial TXD
  •         GPIO_InitStructure.GPIO_Pin = GPIO_Pin_13;
  •         GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;                  //推挽输出
  •         GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;                 //IO口速度为50MHz
  •         GPIO_Init(GPIOC, &GPIO_InitStructure);
  •         GPIO_SetBits(GPIOC,GPIO_Pin_13);
  •         //SoftWare Serial RXD
  •         GPIO_InitStructure.GPIO_Pin = GPIO_Pin_14;
  •         GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IPU;
  •         GPIO_Init(GPIOB, &GPIO_InitStructure);
  •         GPIO_EXTILineConfig(GPIO_PortSourceGPIOB, GPIO_PinSource14);
  •         EXTI_InitStruct.EXTI_Line = EXTI_Line14;
  •         EXTI_InitStruct.EXTI_Mode=EXTI_Mode_Interrupt;
  •         EXTI_InitStruct.EXTI_Trigger=EXTI_Trigger_Falling; //下降沿触发中断
  •         EXTI_InitStruct.EXTI_LineCmd=ENABLE;
  •         EXTI_Init(&EXTI_InitStruct);
  •         NVIC_InitStructure.NVIC_IRQChannel= EXTI15_10_IRQn ;
  •         NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority=2;
  •         NVIC_InitStructure.NVIC_IRQChannelSubPriority =2;
  •         NVIC_InitStructure.NVIC_IRQChannelCmd=ENABLE;
  •         NVIC_Init(&NVIC_InitStructure);
  • void TIM4_Int_Init(u16 arr,u16 psc)
  •         TIM_TimeBaseInitTypeDef  TIM_TimeBaseStructure;
  •         RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM4, ENABLE); //时钟使能
  •         //定时器TIM4初始化
  •         TIM_TimeBaseStructure.TIM_Period = arr; //设置在下一个更新事件装入活动的自动重装载寄存器周期的值
  •         TIM_TimeBaseStructure.TIM_Prescaler =psc; //设置用来作为TIMx时钟频率除数的预分频值
  •         TIM_TimeBaseStructure.TIM_ClockDivision = TIM_CKD_DIV1; //设置时钟分割:TDTS = Tck_tim
  •         TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up;  //TIM向上计数模式
  •         TIM_TimeBaseInit(TIM4, &TIM_TimeBaseStructure); //根据指定的参数初始化TIMx的时间基数单位
  •         TIM_ClearITPendingBit(TIM4, TIM_FLAG_Update);
  •         TIM_ITConfig(TIM4,TIM_IT_Update,ENABLE ); //使能指定的TIM3中断,允许更新中断
  •         //中断优先级NVIC设置
  •         NVIC_InitStructure.NVIC_IRQChannel = TIM4_IRQn;  //TIM4中断
  •         NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 1;  //先占优先级1级
  •         NVIC_InitStructure.NVIC_IRQChannelSubPriority = 1;  //从优先级1级
  •         NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE; //IRQ通道被使能
  •         NVIC_Init(&NVIC_InitStructure);  //初始化NVIC寄存器
  • int main(void)
  •          NVIC_PriorityGroupConfig(NVIC_PriorityGroup_2);//设置中断优先级分组为组2:2位抢占优先级,2位响应优先级
  •          delay_init();
  •          IOConfig();
  •          TIM4_Int_Init(107, 71);         //1M计数频率
  •         while(1)
  •                 if(len > 10)
  •                         len = 0;
  •                         USART_Send(USART_buf,11);
  • void EXTI15_10_IRQHandler(void)
  •         if(EXTI_GetFlagStatus(EXTI_Line14) != RESET)
  •                 if(OI_RXD == 0)
  •                         if(recvStat == COM_STOP_BIT)
  •                                 recvStat = COM_START_BIT;
  •                                 TIM_Cmd(TIM4, ENABLE);
  •                 EXTI_ClearITPendingBit(EXTI_Line14);
  • void TIM4_IRQHandler(void)
  •         if(TIM_GetFlagStatus(TIM4, TIM_FLAG_Update) != RESET)
  •                  recvStat++;
  •                         TIM_Cmd(TIM4, DISABLE);
  •                         USART_buf[len++] = recvData;
  •                         return;
  •                 if(OI_RXD)
  •                         recvData |= (1 << (recvStat - 1));
  •                 }else{
  •                         recvData &= ~(1 << (recvStat - 1));
好好学习,努力赚钱!
