PCB中英对照二、 基材:
PCB中英对照二、 基材:
PCB中英对照二、 基材:
1、 基材:base material
2、 层压板:laminate
3、 覆金属箔基材:metal-clad bade material
4、 覆铜箔层压板:copper-clad laminate (CCL)
5、 单面覆铜箔层压板:single-sided copper-clad laminate
6、 双面覆铜箔层压板:double-sided copper-clad laminate
7、 复合层压板:composite laminate
8、 薄层压板:thin laminate
9、 金属芯覆铜箔层压板:metal core copper-clad laminate
10、 金属基覆铜层压板:metal base copper-clad laminate
11、 挠性覆铜箔绝缘薄膜:flexible copper-clad dielectric film
12、 基体材料:basis material
13、 预浸材料:prepreg
14、 粘结片:bonding sheet
15、 预浸粘结片:preimpregnated bonding sheer
16、 环氧玻璃基板:epoxy glass substrate
17、 加成法用层压板:laminate for additive process
18、 预制内层覆箔板:mass lamination panel
19、 内层芯板:core material
20、 催化板材:catalyzed board ,coated catalyzed laminate
21、 涂胶催化层压板:adhesive-coated catalyzed laminate
22、 涂胶无催层压板:adhesive-coated uncatalyzed laminate
23、 粘结层:bonding layer
24、 粘结膜:film adhesive
25、 涂胶粘剂绝缘薄膜:adhesive coated dielectric film
26、 无支撑胶粘剂膜:unsupported adhesive film
27、 覆盖层:cover layer (cover lay)
28、 增强板材:stiffener material
29、 铜箔面:copper-clad surface
30、 去铜箔面:foil removal surface
31、 层压板面:unclad laminate surface
32、 基膜面:base film surface
33、 胶粘剂面:adhesive faec
34、 原始光洁面:plate finish
35、 粗面:matt finish
36、 纵向:length wise direction
37、 模向:cross wise direction
38、 剪切板:cut to size panel
39、 酚醛纸质覆铜箔板:phenolic cellulose paper copper-clad laminates(phenolic/paper CCL)
40、 环氧纸质覆铜箔板:epoxide cellulose paper copper-clad laminates (epoxy/paper CCL)
41、 环氧玻璃布基覆铜箔板:epoxide woven glass fabric copper-clad laminates
42、 环氧玻璃布纸复合覆铜箔板:epoxide cellulose paper core, glass cloth surfaces copper-clad laminates
43、 环氧玻璃布玻璃纤维复合覆铜箔板:epoxide non woven/woven glass reinforced copper-clad laminates
44、 聚酯玻璃布覆铜箔板:ployester woven glass fabric copper-clad laminates
45、 聚酰亚胺玻璃布覆铜箔板:polyimide woven glass fabric copper-clad laminates
46、 双马来酰亚胺三嗪环氧玻璃布覆铜箔板:bismaleimide/triazine/epoxide woven glass fabric copper-clad lamimates
47、 环氧合成纤维布覆铜箔板:epoxide synthetic fiber fabric copper-clad laminates
48、 聚四乙烯玻璃纤维覆铜箔板:teflon/fiber glass copper-clad laminates
49、 超薄型层压板:ultra thin laminate
50、 陶瓷基覆铜箔板:ceramics base copper-clad laminates
51、 紫外线阻挡型覆铜箔板:UV blocking copper-clad laminates
TEL 18681567708  详情可见www.sz-jlc.com/s
QQ:800058652
