常用晶体管特性参数表
S9018 SMD SINPN15V0.31W600MHZ IRF640 N-FET200V18A125W 77/54ns0.18ohm
2SK1958 SMD N-FET16V0.1A0.15W215/60ns12ohm IRF740 N-FET400V10A125W 41/36ns0.55ohm
S9012 SIPNP25V0.4W 封装:CASE 29-02 IRF9640 P-FET200V11A125W15/12ns0.5ohm
S9013 SINPN25V0.4W封装:CASE 29-02 IRFD120 N-FET100V1.3A1W70/70ns0.3ohm
S9014 SINPN25V0.31W80MHZ IRFD123 N-FET80V1.1A1W70/70ns0.4ohm
S9015 SIPNP25V0.31W150MHZ IXFH75N10 N-FET100V75A250W0.02ohm
A931 SIPNP,VID,150V,0.05A,0.45W
C2331 SINPN,NF/S-L,150V2A15W 11N90 N-FET900V11A250W110/95ns0.95ohm
B647 SIPNP120V1A0.9W140MHZ 可控硅
D667 PA,120V,1A,0.9W140MHZ 可控硅MCR100-6 800MA,400V,触发200UA,800MV
2N4401 SINPN,NF/S,60V,0.6AHEF=40-500 单向可控硅2P4M 4A,400V,触发200UA,800MV
2N4403 SIPNP,NF/S,40V,0.6AHEF=60-500 单向可控硅T106M1 3A,600V,触发10MA,2.2V
2N5401 SIPNP,180V,0.6A 0.31W 双向可控硅BT136 4A,500V,触发70MA,1.5V
2N5551 SINPN,180V,0.6A 0.31W IN4148 调制管75V 450MA
2N2907A SIPNP,60V/60V,0.6A,0.4W26/70NSHEF40-120 IN4001 反压50V,1A瞬时30A正压1.1V反流10UA
2N2907 SIPNP,60V/40V,0.6A,0.4W26/70NSHEF40-120 IN4004 反压400V,1A瞬时30A正压1.1V反流10UA
2N2222 SINPN60V0.8A0.5W25/200NSHEF=100-300 IN4007 反压700V,1A瞬时30A正压1.1V反流10UA
KSP42 NPN,TO92,300V0.5A50MHZ IN5408 反压1000V,3A封装D201AD整流管
KSP44 NPN,TO92,400V0.3A40MHZ IN5817 反压20V,1A封装CASE20703整流管
KSP93 PNP,TO92,200V0.5A50MHZ IN5819 反压40V,1A封装CASE20703整流管
B772 SIPNP, NF/S-L,40V3A10W 快速FR102 高速整流:100V1A封装:D0-41
D882 SINPN,NF/S-L,40V3A30W 快速FR103 高速整流:200V1A封装:D0-41
D1912 LF,PA,60V3A1.75W100MHZ 快速FR107 高速整流:1000V1A封装:D0-41
TIP41C SINPN100V6A3MHZ 快速FR304 高速整流:400V3A250ns封装:SOD64
TIP50 SINPN,S-L,400V,1A40W 瞬变SA30C 稳压管33.3V1MA封装:T0-369-04
TIP122 SINPN,DARL-L,100V8A65W 瞬变P6KE6.8CA 6.8V1MA1.5KW1MS双向二极管
TIP127 SIPNP,DARL-L,100V5A65W 瞬变P6KE15CA 15V1MA1.5KW1MS双向二极管
TIP142 SINPN,DARL-L,100V10A125W 瞬变P6KE33CA 33V1MA600W1MS双向二极管
TIP147 SIPNP,DARL-L,100V10A125W 瞬变P6KE200A 200V1MA600KW1MS双向二极管
BUW13A SINPN850V15A150W 瞬变P6KE440CA 440V1MA600W1MS双向二极管
2SA965 SIPNP,UNI,120V,0.8A,0.9W BYV26C 600V2.3A30ns
2SA1301 PA,160V12A,120W,30MHZ BYV27-200 200V2A25ns
2SC1384 SINPN,60V,1A,1W,200MHZ BYV28-200 200V3.5A30ns
2SC3306 SW,500V10A100WHEF=20 BYV96E 1000V300ns
2SC3281 PA,200V,15A,150WHEF150 HER303 200V4A封装 CASE 267-03
C2502N SINPN,S-L,500V,6A,50W MBR745 肖特基二极管45V7.5A T0220AB
场效应管 MBR1545CT双二极管 肖特基双二极管 高速 2*45V15A
2SK1389 N-FET,60V,50A,125W150/570ns0.025ohm MUR160 600V1A 封装: T0-369-04
IRFZ34 N-FET60V30A90W110/80ns0.05ohm MUR460 600V4A封装:CASE267-03
IRFP150 N-FET100V40A180W210/140ns0.055ohm MUR620C双二极管 2*200V6A 双二极管 T0220AB
IRFP250 N-FET200V33A180W180/120ns0.085ohm MUR1100 快恢复整流管 1000V1A 封装: T0-369-04
IRFP450 N-FET500V14A180W66/60ns0.4ohm MUR4100 快恢复整流管 1000V4A 封装:CASE 267-03
IRFP460 N-FET500V20A250W120/98ns0.27ohm 半桥MUR3040 2*400V30A双二极管封装:T0247
IRF530 N-FET100V14A79W 51/36ns0.18ohm |
