Application Information OUTPUT VOLTAGE SELECTION FOR ADJUSTABLE (LM3674-ADJ) The output voltage of the adjustable parts can be programmed through the resistor network connected from VOUT to FB the to GND. VOUT will be adjusted to make FB equal to 0.5V. The resistor from FB to GND (R2) should be 200 kΩ to keep the current drawn through this network small but large enough that it is not susceptible to noise. If R2 is 200KΩ, and given the VFB is 0.5V, then the current through the resistor feedback network will be 2.5µA. The output voltage formula is: Vout=vfb*(R1/R2+1)
