使用 Karma + Jasmine 构建 Web 测试环境(1)Jasmine 简介更新
使用 Jasmine                编写测试用例下面,我们从一个实际的需求出发,学习如何使用这些方法来编写测试用例。
在开始之前,我们需要先定义应用模型(Model),模型的作用除了定义数据结构,也定义了测试用例的范围。也可以说,这些测试用例其实就是围绕着这些模型展开的。
清单 1.                Mode.js
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
function Student(id, name){
    this.id = id;
    this.name = name;
    this.age = -1;
    this.teacher = null;
function Teacher(id, name){
    this.id = id;
    this.name = name;
    this.age = -1;
function SchoolService(){
    this.getTeachers = function(){
        var teachers = [];
        for(var i=0;i<5;i++){
            var teacher = new Teacher();
            teacher.id = "01" + i;
            teacher.name = "teacher" + i;
            teachers.push(teacher);
        return teachers;
    this.getStudents = function(){
        var students = [];
        for(var i=0;i<10;i++){
            var student = new Student();
            student.id = "00" + i;
            student.name = "student" + i;
            var tId = Math.ceil(i/2);
            teacher.id = "01" + tId;
            teacher.name = "teacher" + tId;
            student.teacher = teacher;
            students.push(student);
        return students;
    this.getTeacher = function(tId){
        var r = null;
        var teachers = this.getTeachers();
        for(var i=0;i<teachers.length;i++){
            var teacher = teachers;
            if(teacher.id == tId){
                r = teacher;
                break;
        return r;
    this.getStudent = function(sId){
        var r = null;
        var students = this.getStudents();
        for(var i=0;i<students.length;i++){
            var student = students;
            if(student.id == sId){
                r = student;
                break;
        return r;
    this.getStudents = function(tId){
        var r = [];
            if(student.teacher && student.teacher.id == tId){
                r.push(student);
        return r;
这里,我们分别定义了 Teacher 与 Student 类,以及对外提供的 SchoolService 类。不难看出 SchoolService                类就是我们需要重点测试的对象。下面,我们来编写测试用例
首先,我们需要测试 getTeachers() 方法
清单 2. 测试                    getTeachers                方法
3
4
5
6
7
8
9
10
11
12
13
describe("A test suite for SchoolService", function() {
    var schoolService = new SchoolService();
    it("Spec test 1, test the getTeachers function", function() {
        var teachers = schoolService.getTeachers();
        expect(teachers).not.toBe(null);
        expect(teachers.length).toEqual(5);
    it("Spec test 2: test the getStudents function", function() {
        var students = schoolService.getStudents();
        expect(students).not.toBe(null);
        expect(students.length).toEqual(10);
接下来,使用较为复杂的 Matchers 测试 getTeacher() 方法
清单 3. 测试                    getTeacher()                方法
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
    it("Spec test 3: test the getTeacher function", function() {
        var teacher = schoolService.getTeacher("011");
        expect(teacher).not.toBe(null);
        expect(teacher.name).toMatch(/teacher/);
        expect(teacher.name).toMatch("teacher");
        expect(teacher.name).not.toMatch(/people/);
        var teacher6 = schoolService.getTeacher("016");
        expect(teacher6).toBe(null);
这时,我们发现每个方法内 teachers 与 students 对象总是重复的出现。因此我们考虑使用 beforeEach / afterEach                方法来优化测试代码
清单 4. 使用                    beforeEach / afterEach                方法
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
    var teachers = [];
    var students = [];
    beforeEach(function() {
    afterEach(function() {
        teachers = [];
        students = [];
更进一步,如果能够将测试用例中的 Teacher 部分与 Student 分开,代码的逻辑就会显得更加整齐,于是,我们想到了使用嵌套测试
清单 5.                使用嵌套测试
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
    //上面的代码与清单4相同
    describe("A nested test suite", function() {
        it("Spec test 4: test the getStudent function", function() {
            var student10 = schoolService.getStudent("0010");
            expect(student10).toBe(null);
            var student9 = schoolService.getStudent("009");
            var teacher = student9.teacher;
            expect(teacher).toBeDefined();
        it("Spec test 5: test the getStudentsByTeacher function", function() {
            var students = schoolService.getStudentsByTeacher("014");
            expect(students.length).toEqual(2);
            var idArray = [];
            idArray.push(students[0].id);
            idArray.push(students[1].id);
            expect(idArray).toContain("007", "008");
而且,一旦不再需要测试 Student 部分,我们只需要将 describe 更改成 xdescribe 即可。这个时候,Jasmine                在运行时就会忽略这部分的测试代码。(如果希望忽略 it 方法,则需要将它改成 xit)
