3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
| #! /bin/sh
# SSID (aka. network name).
SSID='Tenda'
# Network encryption method.
# * 'WPA' for WPA-PSK/WPA2-PSK (note: most Wi-Fi networks use WPA);
# * 'WEP' for WEP;
# * 'Open' for open network (aka. no password).
ENCRYPTION='WPA'
# Network password. (WPA-PSK/WPA2-PSK password, or WEP key)
PASSWORD='pass'
if [ $(id -u) -ne 0 ]; then
printf "This script must be run as root. \n"
exit 1
fi
NETID=$(wpa_cli add_network | tail -n 1)
wpa_cli set_network $NETID ssid \"$SSID\"
case $ENCRYPTION in
'WPA')
wpa_cli set_network $NETID key_mgmt WPA-PSK
wpa_cli set_network $NETID psk \"$PASSWORD\"
'WEP')
wpa_cli set_network $NETID wep_key0 $PASSWORD
wpa_cli set_network $NETID wep_key1 $PASSWORD
wpa_cli set_network $NETID wep_key2 $PASSWORD
wpa_cli set_network $NETID wep_key3 $PASSWORD
esac
wpa_cli enable_network $NETID
wpa_cli save_config
