3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
| # -*- coding: utf-8 -*-
Created on Sun Jan 26 14:24:43 2014
@author: pi
import RPi.GPIO as gpio
import time
gpio.setwarnings(False)
gpio.setmode(gpio.BOARD)
time.sleep(1)
data=[]
def delay(i): #20*i usdelay
a=0
for j in range(i):
a+1
j=0
#start work
gpio.setup(12,gpio.OUT)
#gpio.output(12,gpio.HIGH)
#delay(10)
gpio.output(12,gpio.LOW)
time.sleep(0.02)
i=1
i=1
#wait to response
gpio.setup(12,gpio.IN)
while gpio.input(12)==1:
continue
while gpio.input(12)==0:
continue
continue
#get data
while j<40:
k=0
continue
k+=1
if k>100:break
if k<3:
data.append(0)
else:
data.append(1)
j+=1
print "Sensor is working"
#get temperature
humidity_bit=data[0:8]
humidity_point_bit=data[8:16]
temperature_bit=data[16:24]
temperature_point_bit=data[24:32]
check_bit=data[32:40]
humidity=0
humidity_point=0
temperature=0
temperature_point=0
check=0
for i in range(8):
humidity+=humidity_bit*2**(7-i)
humidity_point+=humidity_point_bit*2**(7-i)
temperature+=temperature_bit*2**(7-i)
temperature_point+=temperature_point_bit*2**(7-i)
check+=check_bit*2**(7-i)
tmp=humidity+humidity_point+temperature+temperature_point
if check==tmp:
print "temperature is ", temperature,"wet is ",humidity,"%"
else:
print "something is worong the humidity,humidity_point,temperature,temperature_point,check is",humidity,humidity_point,temperature,temperature_point,check
