java 架构探险(3)添加Java Web的Maven依赖
五,添加Java Web的Maven依赖
Web项目需要打包成war,需要在pom.xml中配置packaging为war(默认为jar)
<!--配置项目的打包方式,默认jar-->
<packaging>war</packaging>
添加java Web所需Servlet,JSP,JSTL等依赖,完整maven配置pom.xml如下:
<?xml version="1.0" encoding="UTF-8"?>
<project xmlns="http://maven.apache.org/POM/4.0.0"
         xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
         xsi:schemaLocation="http://maven.apache.org/POM/4.0.0
         http://maven.apache.org/xsd/maven-4.0.0.xsd">
    <modelVersion>4.0.0</modelVersion>
    <groupId>org.smart4j</groupId>
    <artifactId>chapter</artifactId>
    <version>1.0.0</version>
    <!--1,(必须)需要统一源码编码方式,否则Maven编译源码时会出现警告,选用UTF-8-->
    <properties>
        <project.build.sourceEncoding>UTF-8</project.build.sourceEncoding>
    </properties>
    <dependencies>
        <!--Servlet provided:只参与编译,不参与打包(tomcat中也有servlet-api包,会冲突)-->
        <dependency>
            <groupId>javax.servlet</groupId>
            <artifactId>javax.servlet-api</artifactId>
            <version>3.1.0</version>
            <scope>provided</scope>
        </dependency>
        <!--JSP provided:只参与编译,不参与打包-->
        <dependency>
            <groupId>javax.servlet.jsp</groupId>
            <artifactId>jsp-api</artifactId>
            <version>2.2</version>
        </dependency>
        <!--JSTL runtime:运行时生效,不参与编译-->
        <dependency>
            <artifactId>jstl</artifactId>
            <version>1.2</version>
            <scope>runtime</scope>
        </dependency>
    </dependencies>
    <build>
        <plugins>
            <!--2,(必须)统一源代码编译输出的JDK版本,本例使用JDK 1.6-->
            <plugin>
                <groupId>org.apache.maven.plugins</groupId>
                <artifactId>maven-compiler-plugin</artifactId>
                <version>3.3</version>
                <configuration>
                    <source>1.6</source>
                    <target>1.6</target>
                </configuration>
            </plugin>
            <!--3,(可选)使用Maven打包时可跳过单元测试-->
            <plugin>
                <artifactId>maven-surefire-plugin</artifactId>
                <version>2.18.1</version>
                <configuration>
                    <skipTests>true</skipTests>
                </configuration>
            </plugin>
            <!--通过Maven将应用不是到Tomcat中-->
            <plugin>
                <groupId>org.apache.tomcat.maven</groupId>
                <artifactId>tomcat7-maven-plugin</artifactId>
                <configuration>
                    <path>/${project.artifactId}</path>
                </configuration>
            </plugin>
        </plugins>
    </build>
</project>
