1、一般这是什么错误:ise9.1i ERROR:Xst:528 - Multi-source in Unit <ram_ctrl> on signal <EN> Sources are: Signal <ram_ctrl_inst/EN> is assigned to logic Signal <ram_ctrl_inst/WE> in Unit <ram_ctrl> is assigned to GND Signal <ram_ctrl_inst/EN> in Unit <ram_ctrl> is assigned to GND 多源是什么意思呀,大家有遇到过这样的问题吗 2、我想用FPGA内部的RAM资源,但是生成的核不能实例化,在仿真顶层文件时它总是报错: # ** Error: (vsim-3033) make_data_top.v(22): Instantiation of 'ram' failed. The design unit was not found. # Region: /make_data_tb_v/uut # Searched libraries: # C:\Modeltech_5.8a\win32\XilinxCoreLib_ver # C:\Modeltech_5.8a\win32\unisims_ver # work 这是什么原因,我装modelsim时生成过xilinx核,大家帮帮忙,谢谢哦 |
