Java 容器源码分析之Map-Set-List(16)
读取这个方法就比较简单了,ArrayList 能够支持随机访问的原因也是很显然的,因为它内部的数据结构是数组,而数组本身就是支持随机访问。该方法首先会判断输入的index值是否越界,然后将数组的 index 位置的元素返回即可。
[url=][/url]
/*** Returns the element at the specified position in this list.** @param  index index of the element to return* @return the element at the specified position in this list* @throws IndexOutOfBoundsException {@inheritDoc}*/public E get(int index) {    rangeCheck(index);    return (E) elementData[index];}private void rangeCheck(int index) {    if (index >= size)    throw new IndexOutOfBoundsException(outOfBoundsMsg(index));}[url=][/url]
删除ArrayList 提供了根据下标或者指定对象两种方式的删除功能。需要注意的是该方法的返回值并不相同,如下:
[url=][/url]
  /**     * Removes the element at the specified position in this list.     * Shifts any subsequent elements to the left (subtracts one from their     * indices).     *     * @param index the index of the element to be removed     * @return the element that was removed from the list     * @throws IndexOutOfBoundsException {@inheritDoc}     */    public E remove(int index) {        rangeCheck(index);        modCount++;        E oldValue = elementData(index);        int numMoved = size - index - 1;        if (numMoved > 0)            System.arraycopy(elementData, index+1, elementData, index,                             numMoved);        elementData[--size] = null; // Let gc do its work        return oldValue;    }/**     * Removes the first occurrence of the specified element from this list,     * if it is present.  If the list does not contain the element, it is     * unchanged.  More formally, removes the element with the lowest index     * <tt>i</tt> such that     * <tt>(o==null&nbsp;?&nbsp;get(i)==null&nbsp;:&nbsp;o.equals(get(i)))</tt>     * (if such an element exists).  Returns <tt>true</tt> if this list     * contained the specified element (or equivalently, if this list     * changed as a result of the call).     *     * @param o element to be removed from this list, if present     * @return <tt>true</tt> if this list contained the specified element     */    public boolean remove(Object o) {        if (o == null) {            for (int index = 0; index < size; index++)                if (elementData[index] == null) {                    fastRemove(index);                    return true;                }        } else {            for (int index = 0; index < size; index++)                if (o.equals(elementData[index])) {                    fastRemove(index);                    return true;                }        }        return false;    }[url=][/url]
注意:从数组中移除元素的操作,也会导致被移除的元素以后的所有元素的向左移动一个位置。
