MapReduce - 编程在线练习处理- select:直接分析输入数据,取出需要的字段数据即可
- where: 也是对输入数据处理的过程中进行处理,判断是否需要该数据
- aggregation:min, max, sum
- group by: 通过Reducer实现
- sort
- join: map join, reduce join
Third-Party Librariesexport LIBJARS=M
Y
LI
B/commons−lang
−2.3.jar,<other
j
ars
u
sed
b
y
r
emote
c
omponents
>had
oopjarprohad
oop−0.0.1−S
N
AP
S
H
OT
.jarorg
.aspress.prohad
oop
.c3.W
ord
C
ountU
sing
oolRunner−libjars
LIBJARS<input_path><output_path>
hadoop jar prohadoop-0.0.1-SNAPSHOT-jar-with-dependencies.jar org.aspress.prohadoop.c3. WordCountUsingToolRunner <input_path>The dependent libraries are now included inside the application JAR file
一般还是上面的好,指定依赖可以利用Public Cache,如果是包含依赖,则每次都需要拷贝 |
