Java 容器源码分析之 ArrayList(3)
添加元素1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
* Appends the specified element to the end of this list.
public boolean add(E e) {
ensureCapacityInternal(size + 1); // Increments modCount!!
elementData[size++] = e;
return true;
* Inserts the specified element at the specified position in this
* list. Shifts the element currently at that position (if any) and
* any subsequent elements to the right (adds one to their indices).
public void add(int index, E element) {
rangeCheckForAdd(index);
System.arraycopy(elementData, index, elementData, index + 1,
size - index);
elementData[index] = element;
size++;
* Appends all of the elements in the specified collection to the end of
* this list, in the order that they are returned by the
* specified collection's Iterator. The behavior of this operation is
* undefined if the specified collection is modified while the operation
* is in progress. (This implies that the behavior of this call is
* undefined if the specified collection is this list, and this
* list is nonempty.)
public boolean addAll(Collection<? extends E> c) {
Object[] a = c.toArray();
int numNew = a.length;
ensureCapacityInternal(size + numNew); // Increments modCount
System.arraycopy(a, 0, elementData, size, numNew);
size += numNew;
return numNew != 0;
* Inserts all of the elements in the specified collection into this
* list, starting at the specified position. Shifts the element
* currently at that position (if any) and any subsequent elements to
* the right (increases their indices). The new elements will appear
* in the list in the order that they are returned by the
* specified collection's iterator.
public boolean addAll(int index, Collection<? extends E> c) {
int numMoved = size - index;
if (numMoved > 0)
System.arraycopy(elementData, index, elementData, index + numNew,
numMoved);
System.arraycopy(a, 0, elementData, index, numNew);
size += numNew;
return numNew != 0;
* Checks if the given index is in range. If not, throws an appropriate
* runtime exception. This method does *not* check if the index is
* negative: It is always used immediately prior to an array access,
* which throws an ArrayIndexOutOfBoundsException if index is negative.
private void rangeCheck(int index) {
if (index >= size)
throw new IndexOutOfBoundsException(outOfBoundsMsg(index));
* A version of rangeCheck used by add and addAll.
private void rangeCheckForAdd(int index) {
if (index > size || index < 0)
| 可以向ArrayList容器中添加单个元素,也可以添加一个容器;默认添加到数组的末尾,也可以添加到指定位置。首先会确认当前容量是否充裕,如果不足则会进行扩容操作。每次添加元素时都会修改modCount的值,前面已经详细地说明过了。在指定添加的位置时,会先检查指定的位置是否合理,不合理则会抛出IndexOutOfBoundsException;如果插入位置合理,则会将相应位置后面的元素向后挪以腾出空间,然后将待添加的元素放入。 |
