Java 容器源码分析之 ArrayList(4)
移除元素1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
* Removes the element at the specified position in this list.
* Shifts any subsequent elements to the left (subtracts one from their
* indices).
public E remove(int index) {
rangeCheck(index);
modCount++;
E oldValue = elementData(index);
int numMoved = size - index - 1;
if (numMoved > 0)
System.arraycopy(elementData, index+1, elementData, index,
numMoved);
elementData[--size] = null; // clear to let GC do its work
return oldValue;
* Removes the first occurrence of the specified element from this list,
* if it is present. If the list does not contain the element, it is
* unchanged. More formally, removes the element with the lowest index
public boolean remove(Object o) {
if (o == null) {
for (int index = 0; index < size; index++)
if (elementData[index] == null) {
fastRemove(index);
return true;
} else {
if (o.equals(elementData[index])) {
fastRemove(index);
return true;
return false;
* Private remove method that skips bounds checking and does not
* return the value removed.
private void fastRemove(int index) {
modCount++;
if (numMoved > 0)
numMoved);
* Removes all of the elements from this list. The list will
* be empty after this call returns.
public void clear() {
modCount++;
for (int i = 0; i < size; i++)
elementData = null;
size = 0;
* Removes from this list all of the elements whose index is between
* {@code fromIndex}, inclusive, and {@code toIndex}, exclusive.
* Shifts any succeeding elements to the left (reduces their index).
* This call shortens the list by {@code (toIndex - fromIndex)} elements.
* (If {@code toIndex==fromIndex}, this operation has no effect.)
protected void removeRange(int fromIndex, int toIndex) {
modCount++;
int numMoved = size - toIndex;
System.arraycopy(elementData, toIndex, elementData, fromIndex,
numMoved);
int newSize = size - (toIndex-fromIndex);
for (int i = newSize; i < size; i++) {
elementData = null;
size = newSize;
| 移除元素时其实就是使用System.arraycopy将移除后仍保留的元素复制到正确的位置上,并调整当前的size大小。注意,在元素移动完成后,要显式地将数组中不再使用的位置中存放的值赋为null,从而确保GC能够正常地回收资源。 |
