Java 容器源码分析之 ArrayList(6)
上面从ArrayList中移除元素的所有方法中都没有对移除元素后的数组大小进行调整,这种情况下可能会在移除大量元素后造成空间的浪费。这时候可以通过trimToSize方法将数组大小调整为实际的大小。
3
4
5
6
7
8
9
10
11
12
13
* Trims the capacity of this ArrayList instance to be the
* list's current size. An application can use this operation to minimize
* the storage of an ArrayList instance.
public void trimToSize() {
modCount++;
if (size < elementData.length) {
elementData = (size == 0)
? EMPTY_ELEMENTDATA
: Arrays.copyOf(elementData, size);
| 更新及查找1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
public boolean contains(Object o) {
return indexOf(o) >= 0;
* Returns the index of the first occurrence of the specified element
* in this list, or -1 if this list does not contain the element.
* More formally, returns the lowest index <tt>i</tt> such that
* <tt>(o==null ? get(i)==null : o.equals(get(i)))</tt>,
* or -1 if there is no such index.
public int indexOf(Object o) {
if (o == null) {
for (int i = 0; i < size; i++)
if (elementData==null)
return i;
} else {
if (o.equals(elementData))
return i;
return -1;
* Returns the index of the last occurrence of the specified element
* More formally, returns the highest index <tt>i</tt> such that
public int lastIndexOf(Object o) {
if (o == null) {
for (int i = size-1; i >= 0; i--)
return i;
} else {
return i;
return -1;
* Returns the element at the specified position in this list.
public E get(int index) {
rangeCheck(index);
return elementData(index);
* Replaces the element at the specified position in this list with
* the specified element.
public E set(int index, E element) {
rangeCheck(index);
E oldValue = elementData(index);
elementData[index] = element;
return oldValue;
| 基于数组的实现使得更新元素及查找元素变得比较简单。在set方法中不会修改modCount的值。 |
