共享模式与基于 Condition 的等待 / 通知机制实现(1)
共享模式acquire实现流程上文我们讲解了AbstractQueuedSynchronizer独占模式的acquire实现流程,本文趁热打铁继续看一下AbstractQueuedSynchronizer共享模式acquire的实现流程。连续两篇文章的学习,也可以对比独占模式acquire和共享模式acquire的区别,加深对于AbstractQueuedSynchronizer的理解。
先看一下共享模式acquire的实现,方法为acquireShared和acquireSharedInterruptibly,两者差别不大,区别就在于后者有中断处理,以acquireShared为例:
3
4
| public final void acquireShared(int arg) {
if (tryAcquireShared(arg) < 0)
doAcquireShared(arg);
这里就能看出第一个差别来了:独占模式acquire的时候子类重写的方法tryAcquire返回的是boolean,即是否tryAcquire成功;共享模式acquire的时候,返回的是一个int型变量,判断是否<0。doAcquireShared方法的实现为:
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
| private void doAcquireShared(int arg) {
final Node node = addWaiter(Node.SHARED);
boolean failed = true;
try {
boolean interrupted = false;
for (;;) {
final Node p = node.predecessor();
if (p == head) {
int r = tryAcquireShared(arg);
if (r >= 0) {
setHeadAndPropagate(node, r);
p.next = null; // help GC
if (interrupted)
selfInterrupt();
failed = false;
return;
if (shouldParkAfterFailedAcquire(p, node) &&
parkAndCheckInterrupt())
interrupted = true;
} finally {
if (failed)
cancelAcquire(node);
我们来分析一下这段代码做了什么:
- addWaiter,把所有tryAcquireShared<0的线程实例化出一个Node,构建为一个FIFO队列,这和独占锁是一样的
- 拿当前节点的前驱节点,只有前驱节点是head的节点才能tryAcquireShared,这和独占锁也是一样的
- 前驱节点不是head的,执行”shouldParkAfterFailedAcquire() && parkAndCheckInterrupt()”,for(;;)循环,”shouldParkAfterFailedAcquire()”方法执行2次,当前线程阻塞,这和独占锁也是一样的
确实,共享模式下的acquire和独占模式下的acquire大部分逻辑差不多,最大的差别在于tryAcquireShared成功之后,独占模式的acquire是直接将当前节点设置为head节点即可,共享模式会执行setHeadAndPropagate方法,顾名思义,即在设置head之后多执行了一步propagate操作。setHeadAndPropagate方法源码为:
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
| private void setHeadAndPropagate(Node node, int propagate) {
Node h = head; // Record old head for check below
setHead(node);
* Try to signal next queued node if:
* Propagation was indicated by caller,
* or was recorded (as h.waitStatus) by a previous operation
* (note: this uses sign-check of waitStatus because
* PROPAGATE status may transition to SIGNAL.)
* and
* The next node is waiting in shared mode,
* or we don't know, because it appears null
* The conservatism in both of these checks may cause
* unnecessary wake-ups, but only when there are multiple
* racing acquires/releases, so most need signals now or soon
* anyway.
if (propagate > 0 || h == null || h.waitStatus < 0) {
Node s = node.next;
if (s == null || s.isShared())
doReleaseShared();
第3行的代码设置重设head,第2行的代码由于第3行的代码要重设head,因此先定义一个Node型变量h获得原head的地址,这两行代码很简单。 |
