共享模式与基于 Condition 的等待 / 通知机制实现(2)
第19行~第23行的代码是独占锁和共享锁最不一样的一个地方,我们再看独占锁acquireQueued的代码:
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
| final boolean acquireQueued(final Node node, int arg) {
boolean failed = true;
try {
boolean interrupted = false;
for (;;) {
final Node p = node.predecessor();
if (p == head && tryAcquire(arg)) {
setHead(node);
p.next = null; // help GC
failed = false;
return interrupted;
if (shouldParkAfterFailedAcquire(p, node) &&
parkAndCheckInterrupt())
interrupted = true;
} finally {
if (failed)
cancelAcquire(node);
这意味着独占锁某个节点被唤醒之后,它只需要将这个节点设置成head就完事了,而共享锁不一样,某个节点被设置为head之后,如果它的后继节点是SHARED状态的,那么将继续通过doReleaseShared方法尝试往后唤醒节点,实现了共享状态的向后传播。
共享模式release实现流程上面讲了共享模式下acquire是如何实现的,下面再看一下release的实现流程,方法为releaseShared:
3
4
5
6
7
| public final boolean releaseShared(int arg) {
if (tryReleaseShared(arg)) {
doReleaseShared();
return true;
return false;
tryReleaseShared方法是子类实现的,如果tryReleaseShared成功,那么执行doReleaseShared()方法:
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
| private void doReleaseShared() {
* Ensure that a release propagates, even if there are other
* in-progress acquires/releases. This proceeds in the usual
* way of trying to unparkSuccessor of head if it needs
* signal. But if it does not, status is set to PROPAGATE to
* ensure that upon release, propagation continues.
* Additionally, we must loop in case a new node is added
* while we are doing this. Also, unlike other uses of
* unparkSuccessor, we need to know if CAS to reset status
* fails, if so rechecking.
for (;;) {
Node h = head;
if (h != null && h != tail) {
int ws = h.waitStatus;
if (ws == Node.SIGNAL) {
if (!compareAndSetWaitStatus(h, Node.SIGNAL, 0))
continue; // loop to recheck cases
unparkSuccessor(h);
else if (ws == 0 &&
!compareAndSetWaitStatus(h, 0, Node.PROPAGATE))
continue; // loop on failed CAS
if (h == head) // loop if head changed
break;
主要是两层逻辑:
- 头结点本身的waitStatus是SIGNAL且能通过CAS算法将头结点的waitStatus从SIGNAL设置为0,唤醒头结点的后继节点
- 头结点本身的waitStatus是0的话,尝试将其设置为PROPAGATE状态的,意味着共享状态可以向后传播
