共享模式与基于 Condition 的等待 / 通知机制实现(4)
Condition的await()方法实现原理—-线程等待前面我们看了Condition构建等待队列的过程,接下来我们看一下等待的过程,await()方法的代码比较短,再贴一下:
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
| public final void await() throws InterruptedException {
if (Thread.interrupted())
throw new InterruptedException();
Node node = addConditionWaiter();
int savedState = fullyRelease(node);
int interruptMode = 0;
while (!isOnSyncQueue(node)) {
LockSupport.park(this);
if ((interruptMode = checkInterruptWhileWaiting(node)) != 0)
break;
if (acquireQueued(node, savedState) && interruptMode != THROW_IE)
interruptMode = REINTERRUPT;
if (node.nextWaiter != null) // clean up if cancelled
unlinkCancelledWaiters();
if (interruptMode != 0)
reportInterruptAfterWait(interruptMode);
构建完毕队列之后,执行第5行的fullyRelease方法,顾名思义:fullyRelease方法的作用是完全释放Node的状态。方法实现为:
3
4
5
6
7
8
9
10
11
12
13
14
15
| final int fullyRelease(Node node) {
boolean failed = true;
try {
int savedState = getState();
if (release(savedState)) {
failed = false;
return savedState;
} else {
throw new IllegalMonitorStateException();
} finally {
if (failed)
node.waitStatus = Node.CANCELLED;
这里第4行获取state,第5行release的时候将整个state传过去,理由是某线程可能多次调用了lock()方法,比如调用了10次lock,那么此线程就将state加到了10,所以这里要将10传过去,将状态全部释放,这样后面的线程才能重新从state=0开始竞争锁,这也是方法被命名为fullyRelease的原因,因为要完全释放锁,释放锁之后,如果有竞争锁的线程,那么就唤醒第一个,这都是release方法的逻辑了,前面的文章详细讲解过。
接着看await()方法的第7行判断”while(!isOnSyncQueue(node))”:
3
4
5
6
7
8
9
10
11
12
13
14
15
| final boolean isOnSyncQueue(Node node) {
if (node.waitStatus == Node.CONDITION || node.prev == null)
return false;
if (node.next != null) // If has successor, it must be on queue
return true;
* node.prev can be non-null, but not yet on queue because
* the CAS to place it on queue can fail. So we have to
* traverse from tail to make sure it actually made it. It
* will always be near the tail in calls to this method, and
* unless the CAS failed (which is unlikely), it will be
* there, so we hardly ever traverse much.
return findNodeFromTail(node);
注意这里的判断是Node是否在AbstractQueuedSynchronizer构建的队列中而不是Node是否在Condition构建的队列中,如果Node不在AbstractQueuedSynchronizer构建的队列中,那么调用LockSupport的park方法阻塞。
至此调用await()方法的线程构建Condition等待队列–释放锁–等待的过程已经全部分析完毕。 |
