万物互联之~网络编程深入篇(2)
万物互联之~网络编程深入篇(2)
2.动态服务器(WSGI)2.1.简化版动态服务器我们先自己定义一个动态服务器:
import reimport socketclass HTTPServer(object):    def __init__(self):        with socket.socket() as tcp_server:            tcp_server.setsockopt(socket.SOL_SOCKET, socket.SO_REUSEADDR, 1)            tcp_server.bind(('', 8080))            tcp_server.listen()            while True:                self.client_socket, self.client_address = tcp_server.accept()                self.handle()    def response(self, status, body=None):        print(status)        header = f"HTTP/1.1 {status}\r\n\r\n"        with self.client_socket:            self.client_socket.send(header.encode("utf-8"))            if body:                self.client_socket.send(body)    def __static_handler(self, name):        try:            with open(f"./www{name}", "rb") as fs:                return fs.read()        except Exception as ex:            print(ex)            return None    def __dynamic_handler(self, name):        try:            m = __import__(name)            return m.application().encode("utf-8")        except Exception as ex:            print(ex)            return None    def handle(self):        with self.client_socket:            print(f"[来自{self.client_address}的消息:]\n")            data = self.client_socket.recv(2048)            if data:                header, _ = data.decode("utf-8").split("\r\n", 1)                print(header)                # GET /xxx HTTP/1.1                ret = re.match("^\w+? (/[^ ]*) .+$", header)                if ret:                    url = ret.groups(1)[0]                    # Python三元表达式(之前好像忘说了)                    url = "/index.html" if url == "/" else url                    print("请求url:", url)                    body = str()                    # 动态页面                    if ".py" in url:                        # 提取模块名(把开头的/和.py排除)                        body = self.__dynamic_handler(url[1:-3])                    else:  # 静态服务器                        body = self.__static_handler(url)                    # 根据返回的body内容,返回对应的响应码                    if body:                        self.response("200 ok", body)                    else:                        self.response("404 Not Found")                else:  # 匹配不到url(基本上不会发生,不排除恶意修改)                    self.response((404, "404 Not Found"))if __name__ == "__main__":    import sys    # 防止 __import__ 导入模块的时候找不到,忘了可以查看:    # https://www.cnblogs.com/dotnetcrazy/p/9253087.html#5.自己添加模块路径    sys.path.insert(1, "./www/bin")    HTTPServer()
效果:
代码不难其中有个技术点说下:模块名为字符串怎么导入?
# test.py# 如果模块名是字符串,需要使用__import__s = "time"time = __import__(s)def application():    return time.ctime() # 返回字符串if __name__ == "__main__":    time_str = application()    print(type(time_str))    print(time_str)
输出:
<class 'str'>Thu Dec 20 22:48:07 2018
