Linux下 df 命令查看磁盘空间(2)
df -m
Filesystem     1M-blocks  Used Available Use% Mounted on
udev                7933     0      7933   0% /dev
tmpfs               1593     2      1591   1% /run
/dev/sda6           9323  7208      1622  82% /
tmpfs               7962    29      7934   1% /dev/shm
tmpfs                  5     1         5   1% /run/lock
tmpfs               7962     0      7962   0% /sys/fs/cgroup
/dev/loop0            13    13         0 100% /snap/gnome-characters/139
/dev/loop2            15    15         0 100% /snap/gnome-logs/37
/dev/loop1           141   141         0 100% /snap/gnome-3-26-1604/74
/dev/loop4            15    15         0 100% /snap/gnome-logs/45
/dev/loop6            35    35         0 100% /snap/gtk-common-themes/808
/dev/loop7             3     3         0 100% /snap/gnome-calculator/238
/dev/loop8            13    13         0 100% /snap/gnome-characters/103
/dev/loop13           35    35         0 100% /snap/gtk-common-themes/818
/dev/loop15           13    13         0 100% /snap/gnome-characters/124
/dev/loop16          141   141         0 100% /snap/gnome-3-26-1604/70
/dev/loop17            3     3         0 100% /snap/gnome-calculator/180
/dev/loop10            4     4         0 100% /snap/gnome-system-monitor/51
/dev/loop11            4     4         0 100% /snap/gnome-system-monitor/57
/dev/loop14            3     3         0 100% /snap/gnome-calculator/260
/dev/loop9            89    89         0 100% /snap/core/5897
/dev/loop12           43    43         0 100% /snap/gtk-common-themes/701
/dev/loop3            90    90         0 100% /snap/core/6130
/dev/loop5            90    90         0 100% /snap/core/6034
/dev/sda7          15559 10303      4447  70% /home
/dev/sda5            180    74        94  45% /boot
tmpfs               1593     1      1593   1% /run/user/121
tmpfs               1593     1      1593   1% /run/user/1000
以人性化的方式查看
df -h
Filesystem      Size  Used Avail Use% Mounted on
udev            7.8G     0  7.8G   0% /dev
tmpfs           1.6G  1.9M  1.6G   1% /run
/dev/sda6       9.2G  7.1G  1.6G  82% /
tmpfs           7.8G   29M  7.8G   1% /dev/shm
tmpfs           5.0M  4.0K  5.0M   1% /run/lock
tmpfs           7.8G     0  7.8G   0% /sys/fs/cgroup
/dev/loop0       13M   13M     0 100% /snap/gnome-characters/139
/dev/loop2       15M   15M     0 100% /snap/gnome-logs/37
/dev/loop1      141M  141M     0 100% /snap/gnome-3-26-1604/74
/dev/loop4       15M   15M     0 100% /snap/gnome-logs/45
/dev/loop6       35M   35M     0 100% /snap/gtk-common-themes/808
/dev/loop7      2.3M  2.3M     0 100% /snap/gnome-calculator/238
/dev/loop8       13M   13M     0 100% /snap/gnome-characters/103
/dev/loop13      35M   35M     0 100% /snap/gtk-common-themes/818
/dev/loop15      13M   13M     0 100% /snap/gnome-characters/124
/dev/loop16     141M  141M     0 100% /snap/gnome-3-26-1604/70
/dev/loop17     2.4M  2.4M     0 100% /snap/gnome-calculator/180
/dev/loop10     3.8M  3.8M     0 100% /snap/gnome-system-monitor/51
/dev/loop11     3.8M  3.8M     0 100% /snap/gnome-system-monitor/57
/dev/loop14     2.3M  2.3M     0 100% /snap/gnome-calculator/260
/dev/loop9       89M   89M     0 100% /snap/core/5897
/dev/loop12      43M   43M     0 100% /snap/gtk-common-themes/701
/dev/loop3       90M   90M     0 100% /snap/core/6130
/dev/loop5       90M   90M     0 100% /snap/core/6034
/dev/sda7        16G   11G  4.4G  70% /home
/dev/sda5       180M   74M   94M  45% /boot
tmpfs           1.6G   20K  1.6G   1% /run/user/121
tmpfs           1.6G   56K  1.6G   1% /run/user/1000
查看某一路径,如/home
df -h /home
