linux字符设备之点亮led (2)
linux字符设备之点亮led (2)
5.到这一步我们驱动程序就写好了
老规矩,makefile,make,拷贝到开发板,insmod led.ko
6.编写测试程序
#include <sys/types.h>
#include <sys/stat.h>
#include <fcntl.h>
#include <stdio.h>
int main(int argc, char **argv)
        int fd;
        int val = 1;
        fd = open("/dev/xyz", O_RDWR);
        if (fd < 0)
                printf("can't open!\n");
        if (argc != 2)
                printf("Usage :\n");
                printf("%s <on|off>\n", argv[0]);
                return 0;
        if (strcmp(argv[1], "on") == 0)
                val  = 1;
        else
                val = 0;
        write(fd, &val, 4);
        return 0;
编译,拷贝到开发板
./led_test on
    灯全亮
谈一谈注册字符设备:
major = register_chrdev(0, "led", &led_fops);
//int register_chrdev(unsigned int major, const char *name,const struct file_operations *fops)
    这个函数没有指定次设备号,所以主设备号下的所有次设备号(0~255)都是对应这个led_fops,非常的霸道,但是我喜欢
    major:主设备号,如果写0,则让内核自动分配主设备号
    fops:自己编写的fops
******ledc.c*******
#include <linux/module.h>
#include <linux/kernel.h>
#include <linux/fs.h>
#include <linux/init.h>
#include <linux/delay.h>
#include <asm/uaccess.h>
#include <asm/irq.h>
#include <asm/io.h>
#include <asm/arch/regs-gpio.h>
#include <asm/hardware.h>
static struct class *led_class;
static struct class_device      *led_class_dev;
volatile unsigned long *gpfcon = NULL;
volatile unsigned long *gpfdat = NULL;
static int led_open(struct inode *inode, struct file *file)
        *gpfcon &= ~((0x3<<(4*2)) | (0x3<<(5*2)) | (0x3<<(6*2)));
        *gpfcon |= ((0x1<<(4*2)) | (0x1<<(5*2)) | (0x1<<(6*2)));
        return 0;
static ssize_t led_write(struct file *file, const char __user *buf, size_t count, loff_t * ppos)
        int val;
        copy_from_user(&val, buf, count); //    copy_to_user();
        if (val == 1)
                *gpfdat &= ~((1<<4) | (1<<5) | (1<<6));
        else
                *gpfdat |= (1<<4) | (1<<5) | (1<<6);
        return 0;
static struct file_operations led_fops = {
    .owner  =   THIS_MODULE,
    .open   =   led_open,
    .write  =   led_write,
int major;
static int led_init(void)
        major = register_chrdev(0, "led_drv", &led_fops);
        firstdrv_class = class_create(THIS_MODULE, "leddrv");
        firstdrv_class_dev = class_device_create(led_class,NULL, MKDEV(major, 0), NULL, "xyz"); /* /dev/xyz */
        gpfcon = (volatile unsigned long *)ioremap(0x56000050, 16);
        gpfdat = gpfcon + 1;
        return 0;
static void first_drv_exit(void)
        unregister_chrdev(major, "led_drv");
        class_device_unregister(led_class_dev);
        class_destroy(led_class);
        iounmap(gpfcon);
module_init(led_init);
module_exit(led_exit);
MODULE_LICENSE("GPL");
