枚举HTML元素及超链接
枚举HTML元素及超链接
#include <mshtml.h>
    INT EnumHtmlElement(IDispatch *pDispDoc, CStringArray &m_listTags, CStringArray &m_listHref)
      m_listTags.RemoveAll();
      m_listHref.RemoveAll();
      IHTMLDocument2* pHTMLDocument2 = NULL;
      IHTMLElementCollection* pColl = NULL;
      HRESULT hr;
      LONG celem = 0;
      if(pDispDoc)
        pDispDoc->QueryInterface( IID_IHTMLDocument2, (void**)&pHTMLDocument2 );
      if(pHTMLDocument2)
        pHTMLDocument2->get_all( &pColl );
      if(pColl)
        pColl->get_length( &celem );
      for ( int i=0; i< celem; i++ )
        VARIANT varIndex;
        varIndex.vt = VT_UINT;
        varIndex.lVal = i;
        VARIANT var2;
        VariantInit( &var2 );
        IDispatch* pDisp = NULL;
        hr = pColl->item( varIndex, var2, &pDisp );
        if (hr == S_OK)
          IHTMLElement* pElem = NULL;
          hr = pDisp->QueryInterface( IID_IHTMLElement, (void **)&pElem );
          if ( hr == S_OK )
            BSTR bstr;
            hr = pElem->get_tagName(&bstr);
            CString strTag = bstr;
            IHTMLImgElement* pImgElem = NULL;
            hr = pDisp->QueryInterface( IID_IHTMLImgElement, (void **)&pImgElem );
            if ( hr == S_OK )
              pImgElem->get_href(&bstr);
              strTag += " - ";
              strTag += bstr;
              m_listHref.Add(bstr);
              pImgElem->Release();
            else
              IHTMLAnchorElement* pAnchElem = NULL;
              hr = pDisp->QueryInterface( IID_IHTMLAnchorElement, (void **)&pAnchElem );
              if ( hr == S_OK )
                pAnchElem->get_href(&bstr);
                strTag += " - ";
                strTag += bstr;
                pAnchElem->Release();
            m_listTags.Add( strTag );
            pElem->Release();
          pDisp->Release();
      if(pColl)
        pColl->Release(); pColl = NULL;
      if(pHTMLDocument2)
        pHTMLDocument2->Release(); pHTMLDocument2 = NULL;
      if(pDispDoc)
        pDispDoc->Release();
        pDispDoc = NULL;
      return (INT)m_listTags.GetSize();
//在HTMLView中测试
    void CWebViewView::OnDocumentComplete(LPCTSTR lpszURL)
        // TODO: Add your specialized code here and/or call the base class
      LPDISPATCH pDisp = GetHtmlDocument();
      CStringArray m_listTags, m_listHref;
      if(EnumHtmlElement(pDisp, m_listTags, m_listHref) > 0)
        TRACE(_T("\nTags\n"));
        for(INT_PTR i=0; i<m_listTags.GetSize(); i++)
          TRACE(_T("%s\n"), (LPCTSTR)m_listTags[i]);
        TRACE(_T("\nhref\n"));
        for(INT_PTR j=0; j<m_listHref.GetSize(); j++)
          TRACE(_T("%s\n"), (LPCTSTR)m_listHref[j]);
      pDisp->Release();
        CHtmlView::OnDocumentComplete(lpszURL);
