因为记录了子窗口原始相位位置,因此不论缩放多少次,相对位置都不会发生变化
#include <Afxtempl.h>
class CWindowSizeMange
protected:
typedef struct _tagSizeData_t
HWND hWndCtrl; //窗口句柄
double fLeft, fTop, fRight, fBottom; //位置相对比例
_tagSizeData_t()
memset(this, 0, sizeof(*this));
//初始化 (记录窗口原始坐标位置)
void Init(HWND hParent, RECT rcParent, HWND hCtrl)
ASSERT(hParent && hCtrl);
hWndCtrl = hCtrl;
//获取控件的坐标
RECT rcCtrl;
GetWindowRect(hCtrl, &rcCtrl);
POINT ptLT = { rcCtrl.left, rcCtrl.top };
POINT ptRB = { rcCtrl.right, rcCtrl.bottom };
ScreenToClient(hParent, &ptLT);
ScreenToClient(hParent, &ptRB);
//计算相对位置
double cx = rcParent.right - rcParent.top;
double cy = rcParent.bottom - rcParent.top;
fLeft = ptLT.x / cx;
fTop = ptLT.y / cy;
fRight = ptRB.x / cx;
fBottom = ptRB.y / cy;
//获取窗口坐标
RECT GetRect(RECT rcParent)
RECT rcCtrl = {0,0,0,0};
if(hWndCtrl)
int cx = rcParent.right - rcParent.left;
int cy = rcParent.bottom - rcParent.top;
rcCtrl.left = (LONG)(cx * fLeft);
rcCtrl.top = (LONG)(cy * fTop);
rcCtrl.right = (LONG)(cx * fRight);
rcCtrl.bottom = (LONG)(cy * fBottom);
return rcCtrl;
}SIZEDATA, *LPSIZEDATA;
protected:
HWND m_hParentWnd;
CArray <SIZEDATA, const SIZEDATA &>m_SizeArray;
CRect m_rcOrgRect;
public:
//初始化
INT_PTR Init(HWND hParent)
ASSERT(hParent && IsWindow(hParent));
m_hParentWnd = hParent;
GetClientRect(hParent, &m_rcOrgRect);
m_SizeArray.RemoveAll();
HWND hWndT = NULL;
while(1)
hWndT = FindWindowEx(hParent, hWndT, NULL, NULL);
if(hWndT)
SIZEDATA m;
m.Init(hParent, m_rcOrgRect, hWndT);
m_SizeArray.Add(m);
else
break;
return m_SizeArray.GetSize();
//缩放窗口控件
void ResizeWindow()
CRect rcClient;
GetClientRect(m_hParentWnd, &rcClient);
if(m_hParentWnd && m_SizeArray.GetSize() > 0
&& rcClient != m_rcOrgRect)
for(INT_PTR i=0; i<m_SizeArray.GetSize(); i++)
SIZEDATA *pm = &m_SizeArray[i];
CRect rcCtrl = pm->GetRect(rcClient);
MoveWindow(pm->hWndCtrl,
rcCtrl.left, rcCtrl.top, rcCtrl.Width(), rcCtrl.Height(), TRUE);
m_rcOrgRect = rcClient;
