Leetcode - Merge Two Sorted Lists 更新
My test result:
和之前的差不多做法,还是比较简单的,除了要处理一些细节问题。
补:只不过可以看出一个明显的问题,头结点需要用if语句来确定,逻辑要麻烦一点。然后网上无意间看到了一个做法,叫做 Dummy Node, 很好,分享如下。
private ListNode merge(ListNode head1, ListNode head2) {
ListNode dummy = new ListNode(-1);
ListNode head = dummy;
while (head1 != null && head2 != null ) {
if (head1.val < head2.val) {
head.next = head1;
head1 = head1.next;
}else {
head.next = head2;
head2 = head2.next;
head = head.next;
if (head1 != null) {
head.next = head1;
else {
head.next = head2;
return dummy.next;
总结: Array
Anyway, Good luck, Richardo!
My code:
* Definition for singly-linked list.
* public class ListNode {
* int val;
* ListNode next;
* ListNode(int x) { val = x; }
public class Solution {
public ListNode mergeTwoLists(ListNode l1, ListNode l2) {
if (l1 == null)
return l2;
else if (l2 == null)
return l1;
ListNode temp = dummy;
while (l1 != null && l2 != null) {
if (l1.val < l2.val) {
temp.next = l1;
l1 = l1.next;
else {
temp.next = l2;
l2 = l2.next;
temp = temp.next;
temp.next = (l1 == null) ? l2 : l1;
return dummy.next;
没什么难的。
差不多的做法。。
想当年, dummy node也不知道啊。
只不过知道了也没多大用。
Anyway, Good luck, Richardo! -- 08/15/2016 |
