Picasso使用简介及分析(2)
Picasso使用简介及分析(2)
2. 加载url,创建并返回一个图片下载请求的构建器RequestCreator
    //不仅仅用来存储图片的URL,
    public RequestCreator load(String path) {
     if (path == null) {
        return new RequestCreator(this, null, 0);
     if (path.trim().length() == 0) {
      throw new IllegalArgumentException("Path must not be empty.");
      return load(Uri.parse(path));
    //请求构建器,用来存储该图片加载任务的一切信息,比如:
    //目标的宽高,图片的显示样式(centerCrop,centerInside),旋转角度和旋转点坐标,以及图片
    RequestCreator(Picasso picasso, Uri uri, int resourceId) {
      if (picasso.shutdown) {
          throw new IllegalStateException("Picasso instance already shut down. Cannot submit new requests.");
      this.picasso = picasso;
      this.data = new Request.Builder(uri, resourceId, picasso.defaultBitmapConfig);
    //对图片设置矛盾之处的校验,校验通过则返回Request对象,该方法在最初方法链的into方法中(createRequest)调用
    public Request build() {
     if (centerInside && centerCrop) {
        throw new IllegalStateException("Center crop and center inside can not be used together.");
    if (centerCrop && (targetWidth == 0 && targetHeight == 0)) {
        throw new IllegalStateException("Center crop requires calling resize with positive width and height.");
    if (centerInside && (targetWidth == 0 && targetHeight == 0)) {
        throw new IllegalStateException("Center inside requires calling resize with positive width and height.");
    //默认的优先级为普通
    if (priority == null) {
        priority = Priority.NORMAL;
    return new Request(uri, resourceId, stableKey, transformations, targetWidth, targetHeight,
        centerCrop, centerInside, onlyScaleDown, rotationDegrees, rotationPivotX, rotationPivotY,
        hasRotationPivot, purgeable, config, priority);  }}
