rpm、yum、编译安装轻松管理centos7程序包(12)
三、yum命令
       yum [options] [command] [package ...]
   OPTIONS:
       a、安装
        install package1 [package2] [...]
# yum install httpd -y
Loaded plugins: fastestmirror, langpacks
Loading mirror speeds from cached hostfile
* base: mirrors.aliyun.com
* extras: mirrors.aliyun.com
* updates: mirrors.aliyun.com
Resolving Dependencies
--> Running transaction check
---> Package httpd.x86_64 0:2.4.6-40.el7.centos will be installed
--> Processing Dependency: httpd-tools = 2.4.6-40.el7.centos for package: httpd-2.4.6-40.el7.centos.x86_64
--> Processing Dependency: libaprutil-1.so.0()(64bit) for package: httpd-2.4.6-40.el7.centos.x86_64
--> Processing Dependency: libapr-1.so.0()(64bit) for package: httpd-2.4.6-40.el7.centos.x86_64
---> Package apr.x86_64 0:1.4.8-3.el7 will be installed
---> Package apr-util.x86_64 0:1.5.2-6.el7 will be installed
---> Package httpd-tools.x86_64 0:2.4.6-40.el7.centos will be installed
Installed:
Dependency Installed:
  apr.x86_64 0:1.4.8-3.el7                           apr-util.x86_64 0:1.5.2-6.el7
Complete!
# rpm -q httpd
        reinstall package1 [package2] [...] (重新安装)
            # 次处与安装没有不同,不做演示,一般用于程序出问题时使用,次处重新安装时不会重新覆盖配置文件。
       b、查看
        repolist:显示当前系统上仓库列表
# yum repolist
repo id                        repo name                                              status
base/7/x86_64                  CentOS-7 - Base - mirrors.aliyun.com                   9,007
extras/7/x86_64                CentOS-7 - Extras - mirrors.aliyun.com                   226
updates/7/x86_64               CentOS-7 - Updates - mirrors.aliyun.com                  940
repolist: 10,173
        list:显示仓库中所有程序包
# yum list
Installed Packages
GConf2.x86_64                           3.2.6-8.el7                    @anaconda
ModemManager.x86_64                     1.1.0-6.git20130913.el7        @anaconda
ModemManager-glib.x86_64                1.1.0-6.git20130913.el7        @anaconda
NetworkManager.x86_64                   1:1.0.0-14.git20150121.b4ea599c.el7
        @anaconda
NetworkManager-adsl.x86_64              1:1.0.0-14.git20150121.b4ea599c.el7
        @anaconda
NetworkManager-bluetooth.x86_64         1:1.0.0-14.git20150121.b4ea599c.el7
        @anaconda
NetworkManager-glib.x86_64              1:1.0.0-14.git20150121.b4ea599c.el7
        @anaconda
NetworkManager-libnm.x86_64             1:1.0.0-14.git20150121.b4ea599c.el7
        @anaconda
NetworkManager-team.x86_64              1:1.0.0-14.git20150121.b4ea599c.el7
        @anaconda
OpenIPMI-libs.i686                      2.0.19-11.el7                  base
OpenIPMI-libs.x86_64                    2.0.19-11.el7                  base
OpenIPMI-modalias.x86_64                2.0.19-11.el7                  base
OpenIPMI-perl.x86_64                    2.0.19-11.el7                  base
OpenIPMI-python.x86_64                  2.0.19-11.el7                  base
PackageKit.i686                         1.0.7-5.el7.centos             base
PackageKit.x86_64                       1.0.7-5.el7.centos             base
PackageKit-browser-plugin.x86_64        1.0.7-5.el7.centos             base
PackageKit-command-not-found.x86_64     1.0.7-5.el7.centos             base
PackageKit-cron.x86_64                  1.0.7-5.el7.centos             base
PackageKit-glib.i686                    1.0.7-5.el7.centos             base
PackageKit-glib.x86_64                  1.0.7-5.el7.centos             base
PackageKit-glib-devel.i686              1.0.7-5.el7.centos             base
PackageKit-glib-devel.x86_64            1.0.7-5.el7.centos             base
PackageKit-gstreamer-plugin.x86_64      1.0.7-5.el7.centos             base
PackageKit-gtk3-module.i686             1.0.7-5.el7.centos             base
PackageKit-gtk3-module.x86_64           1.0.7-5.el7.centos             base
PackageKit-hif.x86_64                   1.0.7-5.el7.centos             base
PackageKit-yum.x86_64                   1.0.7-5.el7.centos             base
     @anaconda:表示安装系统时安装的程序包
     base:表示来自base仓库的包
        info:查看程序包详细信息
# yum info httpd
Installed Packages
Arch        : x86_64
Version     : 2.4.6
Release     : 40.el7.centos
Repo        : installed
From repo   : base
Summary     : Apache HTTP Server
URL         : http://httpd.apache.org/
License     : ASL 2.0
Description : The Apache HTTP Server is a powerful, efficient, and extensible
            : web server.
        provides:查看指定的特性(可以是某文件)是由哪个程序包所提供。
