rpm、yum、编译安装轻松管理centos7程序包(17)
groupinstall:安装包组
# yum groupinstall "Development Tools" -y
Loaded plugins: fastestmirror, langpacks
There is no installed groups file.
Maybe run: yum groups mark convert (see man yum)
Loading mirror speeds from cached hostfile
* base: mirrors.aliyun.com
* extras: mirrors.aliyun.com
* updates: mirrors.aliyun.com
Resolving Dependencies
--> Running transaction check
---> Package autoconf.noarch 0:2.69-11.el7 will be installed
--> Processing Dependency: m4 >= 1.4.14 for package: autoconf-2.69-11.el7.noarch
---> Package automake.noarch 0:1.13.4-3.el7 will be installed
--> Processing Dependency: perl(Thread:ueue) for package: automake-1.13.4-3.el7.noarch
--> Processing Dependency: perl(TAP:arser) for package: automake-1.13.4-3.el7.noarch
Installed:
autoconf.noarch 0:2.69-11.el7 automake.noarch 0:1.13.4-3.el7
bison.x86_64 0:2.7-4.el7 byacc.x86_64 0:1.9.20130304-3.el7
cscope.x86_64 0:15.8-7.el7 ctags.x86_64 0:5.8-13.el7
diffstat.x86_64 0:1.57-4.el7 doxygen.x86_64 1:1.8.5-3.el7
flex.x86_64 0:2.5.37-3.el7 gcc.x86_64 0:4.8.5-4.el7
gcc-c++.x86_64 0:4.8.5-4.el7 gcc-gfortran.x86_64 0:4.8.5-4.el7
git.x86_64 0:1.8.3.1-6.el7 indent.x86_64 0:2.2.11-13.el7
intltool.noarch 0:0.50.2-6.el7 libtool.x86_64 0:2.4.2-21.el7_2
patch.x86_64 0:2.7.1-8.el7 patchutils.x86_64 0:0.3.3-4.el7
rcs.x86_64 0:5.9.0-5.el7 redhat-rpm-config.noarch 0:9.1.0-68.el7.centos
rpm-build.x86_64 0:4.11.3-17.el7 rpm-sign.x86_64 0:4.11.3-17.el7
subversion.x86_64 0:1.7.14-10.el7 swig.x86_64 0:2.0.10-4.el7
systemtap.x86_64 0:2.8-10.el7
Dependency Installed:
cpp.x86_64 0:4.8.5-4.el7 dwz.x86_64 0:0.11-3.el7
gettext-common-devel.noarch 0:0.18.2.1-4.el7 gettext-devel.x86_64 0:0.18.2.1-4.el7
glibc-devel.x86_64 0:2.17-106.el7_2.4 glibc-headers.x86_64 0:2.17-106.el7_2.4
kernel-devel.x86_64 0:3.10.0-327.10.1.el7 kernel-headers.x86_64 0:3.10.0-327.10.1.el7
libgfortran.x86_64 0:4.8.5-4.el7 libmpc.x86_64 0:1.0.1-3.el7
libquadmath.x86_64 0:4.8.5-4.el7 libquadmath-devel.x86_64 0:4.8.5-4.el7
libstdc++-devel.x86_64 0:4.8.5-4.el7 m4.x86_64 0:1.4.16-10.el7
mokutil.x86_64 0:0.9-2.el7 neon.x86_64 0:0.30.0-3.el7
pakchois.x86_64 0:0.4-10.el7 perl-Error.noarch 1:0.17020-2.el7
perl-Git.noarch 0:1.8.3.1-6.el7 perl-TermReadKey.x86_64 0:2.30-20.el7
perl-Test-Harness.noarch 0:3.28-3.el7 perl-Thread-Queue.noarch 0:3.02-2.el7
perl-XML-Parser.x86_64 0:2.41-10.el7 perl-srpm-macros.noarch 0:1-8.el7
subversion-libs.x86_64 0:1.7.14-10.el7 systemtap-client.x86_64 0:2.8-10.el7
systemtap-devel.x86_64 0:2.8-10.el7
Dependency Updated:
libgomp.x86_64 0:4.8.5-4.el7 rpm.x86_64 0:4.11.3-17.el7
rpm-build-libs.x86_64 0:4.11.3-17.el7 rpm-libs.x86_64 0:4.11.3-17.el7
rpm-python.x86_64 0:4.11.3-17.el7 systemtap-runtime.x86_64 0:2.8-10.el7
Complete! |
