简单易用的iOS数据库操作框架(2)
简单易用的iOS数据库操作框架(2)
创建和数据库
[[JCDBManager sharedManager] createWithDBName"testDB.sqlite"];
关闭数据库
[[JCDBManager sharedManager] closeDB];
创建表
[JCTestRecord createTable];
添加表字段
[JCTestRecord alterTableWithColumn"testUnsignedLongLongInt"];
删除表
[JCTestRecord dropTable];
插入或替代当前记录
    JCTestRecord *record = [[JCTestRecord alloc] init];
    record.testPrimaryKey = [NSString stringWithFormat"primaryKeyProperty%@", @(index + 1)];
    record.testIgnore = @"ignoreProperty";
    record.testMutableString = [[NSMutableString alloc] initWithString"mutableStringProperty"];
    record.testNumber = @(6.20);
    record.testDecimalNumber = [[NSDecimalNumber alloc] initWithString"2016"];
    record.testDate = [NSDate date];
    record.testData = [@"dataProperty" dataUsingEncoding:NSUTF8StringEncoding];
    record.testMutableData = [NSMutableData dataWithData:[@"mutableDataProperty" dataUsingEncoding:NSUTF8StringEncoding]];
    record.testBOOL = YES;
    record.testShort = 6;
    record.testInt = 20;
    record.testLong = 20160620;
    record.testInteger = index + 1;
    record.testEnumType = (index + 1) % 3;
    record.testInt64 = (index + 1)*24*3600;
    record.testUInteger = 201606;
    record.testFloat = 10.5;
    record.testCGFloat = 1.26;
    record.testDouble = 10.52;
    record.testTimeInterval = 978307200.0;
    record.testLongInt = 10000010;
    record.testLongLongInt = 1000000110;
    record.testUnsignedLongLongInt = 100000000111;
    BOOL result = [record updateRecord];
更新当前记录字段值
    result = [record updateRecordColumns[@"testBOOL", @"testDate", @"testNumber"]
                                  values[@(NO), [NSDate dateWithTimeIntervalSince1970:9], @(6.22)]];
删除当前记录
result = [record deleteRecord];
查询记录
JCTestRecord *record = [JCTestRecord queryRecordWithPrimaryKeyValue"primaryKeyProperty2"];
NSArray *queryRecords = [JCTestRecord queryRecordsWithConditions{@"testEnumType"(JCTestEnumTypeTwo)}];
    queryRecords = [JCTestRecord queryRecordsWithConditionalExpression:@"WHERE testEnumType < ?"
                                                             arguments:@[@(JCTestEnumTypeTwo)]];
    queryRecords = [JCTestRecord queryRecordsWithConditionalExpression:@"ORDER BY testEnumType DESC"
                                                             arguments:nil];
queryRecords = [JCTestRecord queryAllRecords];
查询记录的相关字段
    NSArray *queryColumns = [JCTestRecord queryColumns:@[@"testPrimaryKey", @"testDate"]
                                 conditionalExpression:@"WHERE testEnumType < ? ORDER BY testInteger DESC"
                                             arguments:@[@(JCTestEnumTypeOne)]];
查询表中记录条数
uint64_t count = [JCTestRecord countRecordsWithConditions:@{@"testEnumType":@(JCTestEnumTypeTwo)}];
    count = [JCTestRecord countRecordsWithConditionalExpression:@"WHERE testEnumType < ?"
count = [JCTestRecord countAllRecords];
删除记录
BOOL result = [JCTestRecord deleteRecordsWithConditions:@{@"testEnumType":@(JCTestEnumTypeTwo)}];
    result = [JCTestRecord deleteRecordsWithConditionalExpression:@"WHERE testEnumType < ?"
result = [JCTestRecord deleteAllRecords];
以上就是该框架现有的内容,支持sqlite大部分的增删改查操作,对于可能出现的其他需求,还需要大家一起添砖加瓦。
