Spark 2.0, high level concept
Entry point and basic abstraction
For Spark base
main entry point: SparkContext
basic abstraction: RDD
For Spark SQL
main entry point: SparkSession
basic abstraction: DataFrame
For Spark Streaming
Main entry point:
basic abstraction: DStream
For Spark ML
Main entry point:
Core Classes
    Spark base
    pyspark.SparkContext
    Main entry point for Spark functionality.
    pyspark.RDD
    A Resilient Distributed Dataset (RDD), the basic abstraction in Spark.
    Spark Streaming
    pyspark.streaming.StreamingContext
    Main entry point for Spark Streaming functionality.
    pyspark.streaming.DStream
    A Discretized Stream (DStream), the basic abstraction in Spark Streaming.
    Spark SQL and DataFrame
    pyspark.sql.SQLContext
    Main entry point for DataFrame and SQL functionality.
    pyspark.sql.DataFrame
    A distributed collection of data grouped into named columns.
Spark running mode
Locally
Cluster
Setup and run/submit job
Locally
Setup
Spark shell and submit job
    ./bin/spark-shell --master local[2]
    OR
    ./bin/pyspark --master local[2]
Submit job
    ./bin/spark-submit examples/src/main/python/pi.py 10
    OR
    ./bin/spark-submit examples/src/main/r/dataframe.R
Spark Stand alone cluster
Spark YARN cluster
What ?
:paste
:help
Spark context available as sc.
SQL context available as sqlContext.
Read csv files as Dataframe in Apache Spark with spark-csv package. after loading data to Dataframe save dataframe to parquetfile.
    val df = sqlContext.read
          .format("com.databricks.spark.csv")
          .option("header", "true")
          .option("inferSchema", "true")
          .option("mode", "DROPMALFORMED")
          .load("/home/myuser/data/log/*.csv")
    df.saveAsParquetFile("/home/myuser/data.parquet")
    val df_1 = sqlContext.read.parquet("/Users/user_name/Work/tmp/sample.parquet")
    df.dtypes
    df.show()
